Question about Lincoln Electric Welding Tools
Electrical troubleshoot Explain how to solve general problem
  • bryan lawless
    bryan lawless May 06, 2014
    Take it out of the box first. 2nd step is to plug it in. 3rd is to turn it on and see if it welds. With the vast amount of information received this should fix it!
  • Patrick Masue May 09, 2014
    I dont understand your question, be more explicite and may be we can help you
I have an electrical problem in the dashboard of my 1999 GMC sierra.
Please explain the problem in detail. In general these clusters have many problems mostly with the instrument displays, the best thing to do is pull the cluster out and have it rebuilt with the newest improved parts. Repair centers are all over the web, just google it.
Apr 27, 2012 | 2002 GMC Sierra C/K1500
Their is a work going on in ground floar, that creates problems in the structure of 1st and 2nd floar of the building. What can be done? Also where to complain, if i stay in new delhi?
Of course it is a possibility depending on where your electrical service is I would explain your problem to the General contractor so he can talk to the electrician if such a project is going on .
Nov 19, 2010 | Hammering
Is there any way I can get the electrical drawings for the D61130
No,these schamatics diagrams drawings,don't get release to the general public.What wrong with tv,tell me might help u to solved the probems.
Oct 25, 2010 | RCA D61130 61" Rear Projection Television
My IPhone 3gs gives the message "Mailbox is full" when called and not answered but there are no saved messages. Help!
Try Settings - General >Reset >Reset network connections.
and then power the phone off and back on again.
If the problem consists, call At&t and explain the problem. They should be able to reset the phone and solve the problem.
If you do call, make sure you call from another phone that doesn't have the problem.
Sep 16, 2010 | Apple iPhone 3G
Oven seems to have some sort of electrical problem
I just solved a similar probelm with my Kenmore oven, gave error code f7, among others. The control panel is manufactured by General Electric. Turned out that the control panel has a electrical ribbon that goes to the relay panel. The ribbon is actually two ribbons pressed together. They should easily pull apart. They are not insulated properly, and the ribbon leads short together or cross. Just put a piece of paper between them to act a an insulator. Good luck!
Nov 08, 2009 | Ovens
General list of manufacturer and models.
i can't watch vedio on youtube that say bad request please solve that thankyou.
Feb 19, 2009 | Computers & Internet
General electronics
and what wouldn't work if one or the other went bad? Right now when I turn the key from OFF to ACCESSORIES the headlight will come on and the starter will run when pressed (the bike won't start though) but when I switch the key to IGNITION everything goes dead. The switch is new so it's probably not that. I'm not an electrical system expert but this guy's page has helped me many times. He discusses rectifiers about a third of the way down... but you'll probably learn a lot by reading the whole page and eventually the whole site. He has really good info about most aspects of MC repair. http://www.dansmc.com/electricaltesting.htm,,
Nov 10, 2008 | 2008 Beta RR 400
Screen touch is not functioning
A general fault is that the touch screen or its control devices has failed. In some cases, the ribbon cables or the pressure contacts between the screen and its controler are not making good contact.
If there is an electrical fault, the fix is to replace the touch screen, and its controler. In many of these types of phones everything is on the main circuit board. The general fix is to replace the main circuit board, or to replace the screen assembly.
The main cause of failure for these devices is dropping the phone, or getting it wet.
Jerry G.
Sep 27, 2008 | HTC Touch P3450 Smartphone
Welding Tools Logo
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
