Question about HP LaserJet 3050 All-In-One Printer
Scanner problem black blank print gets while scanning what is the reason for this?
  • HP Expert
  • 398 Answers
Gunk on scan glass. -Carl
Posted on Apr 21, 2014
4 Suggested Answers
  • 360 Answers
SOURCE: Scanned pictures are black and white
if the unit makes color copies correctly, the scanner is working correctly, the application you are scanning to sets the size, resolution, color/b&w, etc. you will need to enter into the application and set it for color.
if u have any ?'s let us know, we will Fix Ya.
clarkco
Posted on Feb 06, 2009
don_farr
  • 1018 Answers
SOURCE: Scanner scans but does not see what is on the bed
Do you see the scanner lamp come on?
If you do not see the lamp, then the failure may be that the lamp or the power supply for the lamp have been comprised.
Please find a local authorized repair center and have the printer tested and repaired.
Don
Posted on Dec 12, 2009
SOURCE: only scans and copies black blank
you're helpful.
Posted on Jul 05, 2008
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
Right side of document is black when scanning to print, umax 1220u
1. Fred's right about trying another computer, but you still may have wrong/ old driver- download demo version of Vuescan at www.hamrick.com and see if it's your software.
2. Partially blank pages can appear when you don't have sufficient memory for the scan, but that usuall loosees the lower half of the page.
3. The lamp is probably not the problem, because there is enough liht bouncing around in mostflatbead scanners that you would just see the image "fade"to black, not have a distinct line.
4. best bet is that something inside has come loose and is covering half the scanning sensor, or the mirrors that reflect the images to the sensor inside
Dec 24, 2012 | Umax Astra 1220U Flatbed Scanner
Scanner component scans and prints normally. Trying to print off an e-mail is a different story. The little screen says 'printing' and it goes through the motions. You can hear the carriage travelling line...
check the ink cartidges (the color ones) scanners use just black ink to print with (all grayscale) if you can't buy/ afford cartidges right now (who ISN'T broke these days!?!) then set the preferances on the printer to "black/ grayscale" and see if that works ( also is a good test to see if ink is out)
Mar 04, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
My canon MP40 will not scan/copy
This is because you have NOT installed the actual Drivers for the scanner and the Scan Manager. Driver link below. Ensure you get entire package A:SO get the user manual, it shows you what to do.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
May 14, 2010 | Canon PIXMA MX310 All-In-One Printer
Only scans and copies black blank
please check if the exposure lamp. or the ligth that runs when scanning works if it does not turn on change that parts
Jun 16, 2008 | HP PSC 1510 All-In-One InkJet Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Apr 09, 2008 | Canon DR-9080C Path-Through Scanner
Printing blank pages
Make sure your set to "print" and not scan. The blank pages may be a 'print' of the lid on your scanner top
Feb 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
