In the FCA610 control panel on the Synchronization page "Manual" is selected, and cannot be changed. Sync frequency cannot be changed because of an error message "Select sample rate failed. Audio streaming in progress." How do I turn off audio streaming so I can change the sample rate?
Most advanced music software propose a menu to set the sample rate and resolution, so you can use your audio interface without setting the sample rate in the control panel.
If you want to set it anyway, in case you are in Windows (for example Windows 7), you can click on Windows button (Start button on older Windows), choose Control panel, go to Sound, and in Sound, you can select Inspire 1394 in the playback list, and click on properties.
In the Advanced tab, you get the default playback format, for example 24-bit 96KHz, and you can change it.
<p>A phone with Android can synchronize accounts with Google
Gmail, Google Calendar and Google Contacts. You can select what to sync Google
Account if you do not want them all, all computers and sync Android phone.
Manually synchronize your accounts when you make changes that are not reflected
on your Android phone. <br />
<p><br />
<p>1. Tap the "Applications" below. <br />
<p><br />
<p>2. Scroll down until you app "My Account" and tap
it. <br />
<p><br />
<p>3. Choose your Google Account and customize your
synchronization options. Gmail, Calendar and Contacts synchronization are
available and you can turn on and off at will. <br />
<p><br />
<p>4. Press the menu button Android. Tap the "Sync
Now" synchronization between your phone and select the Google Account and
power applications. <br />
Why did my Mp3 Player Add/Delete a File I Didn't Want? Manual vs. Automatic Synchronization in Windows Media Player
by Tha Mp3 Doctor
The difference between manual and automatic synchronization is very important. If you’re ever wondering why you computer added files to your device when you didn’t want it to, or why it deleted files unexpectedly, then there is a good chance that you have automatic synchronization activated. Manual synchronization allows you to only add/delete only those files that you want to keep or discard.
There are many good outside websites out there – many with videos on how to do everything we have described in these pages. Hopefully, this will give many of you a start into the wonderful world of music transfer through mp3 players and Windows Media Player.
The power supply for the FCA202 is rated for 12V DC at 200 mA. (The AC power adapter connects to 120V AC, 60 Hz in the US. The UK version is for 240V, 50Hz.)
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.)
With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
