Question about Car Audio & Video
Car stereo will not power on
My stereo suddenly would only play from the tape deck and then later would not even turn on. nothing will function at this time, cd's cannot be put in or tapes.
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Have u check ur fuses in ur van u need to check the auxilory and the streo one in front and inside ur car
Posted on Jun 28, 2009
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
The cassette deck in my '95 BMW 325i now just flips from side 1 to side 2, without actually playing. Everything else with the stereo still works fine. Might this be a problem that a non-profession
The unit has to come out of the car and taken to a auto Stereo repair shop. I would guess without seeing it that there is a loose belt that is causing a detection of the deck not turning the reel the detector is on and that tells the electronics the tape has stopped and if there is no drive in the other direction it does the same thing. If a capstan belt breaks there is no drive in either direction. The belt may not be hard to replace but you need to know the routing and the size then just order from MAT Electronics or MCM Electronics and put it in. I also think the Head and Pinch Rollers are going to need a real good cleaning. Use Naphtha for that. I serviced car stereos back in the 80 and 90 not so much anymore. If you can do it depends on your technical ability.
Jan 20, 2013 | Audio Players & Recorders
I have had my 1991 lexus ls400 for a couple years now and I've been using the cassette deck in the stock stereo unit all the time by using one of those cassettes with the 3.5mm headset wires coming out...
The tape deck in the unit probably needs to be fixed. Even though you are using an artificial tape supplying a signal to the heads, there are still motors and belts running in the unit if it thinks a tape is in there. Now a belt or a motor has failed and the deck will not stay in tape mode. Thus pulling the unit out of the dash and having it serviced will be required to use this I pod function. There has to be easier ways to do this- I would consult Crutchfield about it.
Nov 08, 2012 | Audio Players & Recorders
Pioneer Stereo double cassette deck Ct-W302R - is it repairable?
They might be repairable but usually at a cost that exceeds it value. Who wants to pay $150 to fix what was known as a throw away tape deck? Not many. It might even exceed $150 as they are complicated to repair bot being designed to be repaired.
Mar 22, 2012 | Pioneer Audio Players & Recorders
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Nak cass deck 1 stops suddenly..
Sounds like it could something wrong with the auto stop function (used to stop the deck when it gets to the end of the tape). There's normally some kind of leaver that pushes into the tape. When the tape get's stiff, it pushes back and sets in motion the stop. I would check that out. Another cause is solenoid problems.
Mar 22, 2010 | Audio Players & Recorders
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
