Question about Ryobi Drills
I need to repair my ryobi router
I've used it, and then later it would not fire up?
    Sniper:
  • 103 Answers
Yes change your brushes
Posted on Dec 07, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Pull the brushes out and make sure they are in good shape. Sping the motor by had then put the brushes back in and see if it works. Often times the brushes get blocked by wood dust. If not check the power cord and switch for continuity.
Posted on Apr 22, 2014
Model R163GK router. Where can I get a working manual?
The user's manual for the Ryobi R163GK fixed base router is available from Home Depot on the product page: http://www.homedepot.com/p/Ryobi-8-5-Amp-Fixed-Base-Router-R163GK/205179539 . Look on the right hand side of the page for the Use and Care Manual. The direct link to the manual is http://www.homedepot.com/catalog/pdfimages/de/deaea807-a602-4a2e-b637-e30019a5f34f.pdf .
I hope this helps. I think the K indicates that the unit was for Home Depot sales; the router is the same as the R163/R163G. Ryobi has the same manual here, https://www.ryobitools.com/power-tools/support/manuals , if you leave off the K.
Feb 23, 2016 | Ryobi Tools & Hardware - Others
Hello I have a ryobi router table ART3 what router will fit this table the manual say's a ryobi 163 but I live in Australia and can't even find a second hand one , their are plenty in America but they are...
If its not and adjustable table and you can't find one, modify the mount to fit yours.Most of the time all you will need to do is drill 4 holes in the top of the base to match your router base. Easiest way to set it up is to remove the router base from your unit and use the holes as a template to drill the holes.
Feb 06, 2015 | Ryobi Tools & Hardware - Others
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
Help, I have a Model 315.242130 Router. The motor housing body(plastic) has been worn thru use and when I had it attached to my table saw with router attachment(also sears) it became clogged with wood...
These were made by Diehl Manufacturing Co In 1988 the Motor Products Division of Diehl was acquired by Japanese power tool maker Ryobi, Ltd., becoming the basis of Ryobi's new U.S. operations, Ryobi Motor Products Corp.; Ryobi took over supply of products to Sears Craftsman, retaining the 315 manufacturer code.
So... it appears you can use a Ryobi part. this may sound sarcastic but.. even as a seasoned expert we could spend hours searching ryobi router parts and still not find you a 100% match.
Spend some time using this page and see if you find a match:
http://www.ereplacementparts.com/ryobi-router-parts-c-7931_8117.html
Click on the individual corded router links.
Just trying to help you,
Kelly
May 25, 2011 | Garden
I need a Switch Triger for a Ryobi Roiuter model R161
you are going to have a problem finding one. The switch is showing as obsolete no replacement at 2 different sites. I would make a wiring diagram and if you have a local repair shop see if they can match it up with another mfr's switch. If they do it has to have the same ratings and specs.
May 24, 2011 | Ryobi ROUTER KIT P163K
Hi i have a ryobi r / 150 router which i,ve broken the collet chuck and bit adapter where can i buy them from,i live in victoria. kind regards dave.
Check here -> http://www.ryobitools.com/support/parts_batteries#
They handle just about everything, don't let battery tag deter you.
Mar 03, 2011 | Ryobi ROUTER KIT P163K
My ryobi fixed-base router is very difficult to adjust its depth.
Clean the router after each use some have grooved plastic threads surrounding the motor that get plugged up. Normal use and design may be a factor.
Feb 20, 2011 | Ryobi ROUTER KIT P163K
Need a manual and two (2) wrenches for a ryobi r30 router
found the wrench number but no manual you will have to call Ryobi direct at 1-800-525-2579 for the manual the wrench number is 975096001 and they list for around 2.05 each.
Oct 14, 2009 | Ryobi Tools & Hardware - Others
Ryobi edger, trimmer, weedeater was working fine for 30 minutes. Then machine was stopped to put on another tool attachment. It was restarted and worked, then not long after, it completely conked out....
If the trimmer has fire, (spark) Then:
check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 18, 2009 | Ryobi Garden
Manual for Ryobi R1801m1 router
http://ryobitools.arinet.com/scripts/EmpartISAPI.dll?MF
I think you mean R180 router. This is Ryobi's site the manual section. Even if your particular router is not listed you should be able to draw from the information listed for similar router there.
Mar 29, 2009 | Ryobi Tools & Hardware - Others
Drills Logo
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
