Question about Coffee Makers & Espresso Machines
Delonghi magnifica no coffee coming from infuser
ginko
  • 19396 Answers
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Posted on Apr 18, 2009
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
mnwarfield10
  • 452 Answers
SOURCE: delonghi magnifica rapid cappuccino model EAM
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Posted on Feb 27, 2011
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Infuser will not come out, can anyone help?
the infuser is tilted and I cannot get it back to center
Jul 20, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
15 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
