Question about Motorola Mobility RAZR V3i Cellular Phone
Cannot access memory card
When I try to access memory card contents from mobile set, I couldn't.
It always says the memory card is empty.
But when I connect it to my PC and I can be able to access the contents.
Any help is greatly appreciated.
    Brigadier General:
  • 7,752 Answers
Re: cannot access memory card
What to do you can copy all of the contents from your card to the pc...then reformat the card and add back the content to the card and put it in the phone.
If that does not help then try the card in another phone and if it reads then your phone needs to be checked.
Posted on Jun 29, 2008
0 characters
3 Points
I got " memory full,
when you recive any thing it go to mobile memory.change msg setting and set memory card there.then when you recive any thing through bluethooth its goes direct to the memory card.
i dont have nokia mobile other wise i tell you full steps.but i know its creapy problem with all nokia mobiles.
Jun 13, 2011 | Nokia C201 Cell Phone
My phone always flashes memory full but the phone and memory card is empty
reset the mobile to the factory defualt and format the memory card.
May 09, 2011 | LG GT350 Cell Phone
Hello I am having samsung GT-E1410 mobile. I am
You cannot receive files on your memory card directly.
You are to receive it on your phones memory, then you move it to you memory card.
You ensure your phones memory is totally empty so you can receive your incoming files.
Go to messages,
select the message settings,
select the message sending option,
Select save and send.
once this is done, you will be able to view your sent mails in your outbox.
Take care
Jun 20, 2010 | Cell Phones
Unlock Memory card - N73
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer,
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
May 23, 2010 | Nokia N73 Cellular Phone
Nokia pcsuite can't access my phone. currently i'm using onetouch internet service. but other options can't access my phone.
Sorry to saying you but virus has been taken place in your memory card & may be it will come in mobile through memory card.
so kindly format your mobile phone & memory card.
& always use quickheal anti virus & regularly update it.
Because it is best antivirus for mobile phone attaching purpose.
Thank You.
Jan 27, 2010 | Cell Phones
Slow access to memory card
hey there....feels so good to see people using that same l9 as mine.....and about the card works well on my phone ..yeah 2 gb...what you can do is arrange all the contents(from a computer) on your card according to their formats in the MOBILE FOLDER AND ITS SUBFOLDERS AS - VIDEO , PICTURES, AUDIO.....this should help...tell me if this doesn`t....
AND please VOTE us to help you better
Aug 18, 2009 | Motorola Mobility L9 Unlocked GSM Cell...
How to deleat some data
Change the memory to memory card , it should solve the problem or connect it to the PC and delete the data from the phone memory.
Always use memory card for Messages, contacts and multimedia content, if you do not change the memory cards often.
Sep 25, 2008 | Nokia N91 Cellular Phone
Nokia 3110 Cellular Phone Problem memory card password lock
Hi Amit,
I feel that you may have to format your memory card. As u said u don't mind loosing data then that's the only way to enable u to start using it again.
This should work.
TIP: Always make it a point to backup the contents of your mobile phone's memory card, especially the phone book & SMSs if important & necessary. This way your loss is minimised.
May 06, 2008 | Nokia 3110 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
