Question about Home
Folding paper over a radius corner on a book - Home
3 Suggested Answers
SOURCE: HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Posted on Aug 20, 2008
  • 43 Answers
SOURCE: hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Posted on Jun 18, 2009
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
On the front of the printer Lexmark E120 a picture of paper with a corner folded down. Printer wont print and there is no paper jam, what does that one mean?
The picture of paper with a corner folded down is Load/Remove paper. Can you describe the status lights of the printer? The light sequence will indicate specific error and status of the printer.
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark E120n Laser Printer
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
How to install adding machine tape to a radioshack EC-3033
Here is the link to the instruction book for that calculator. It describes how to install the paper into the machine. The only thing I could recommend different is to fold the lead edge of the paper to a 45 degree angle /| instead of the straight edge the book is recommending. Sometimes there is a small blockage in the feed path and the angled fold will get the lead edge passed it enough for the feed rollers to catch the paper. The blockage usually feeds out with when the edge of the paper clears the rollers. I would try it by the book first then try the folded edge. The only other option would be a middle fold /\ in case the blockage is on the edge you folded from in the first attempt
Link to EC-30333 book
http://support.radioshack.com/support_radios/doc46/46048.htm
Hope that helps
Jun 12, 2010 | Casio FR-2650A Calculator
After several copies the paper gets very warm and paper rolls on the edge and jams
Rolls on the edge meaning it curls upward or folds a corner? You might try pullig out the paper cassette (tray), removing the entire contents and flip upside down (face down) this should help to alievate paper curl. If it is folding corners, you may need to have serviced. Let me know, please.
Oct 09, 2009 | Canon PC-1080F Plain Paper Laser Fax
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Aug 08, 2008 | HP LaserJet 4350 Printer
Corners folding while copying
if it is just folding the paper back without pressing it, then its a problem in the fuser. Paper sticking to long to the upper fuser roller and catching either a pick off finger or a mylar on the exit of the fuser.
Hope that helps...
Jun 17, 2008 | Ricoh Aficio 1035 Copier
Bell & Howell Copiscan Spectrum corner problems
It can be a nightmare to find out what is causing the dog ear page or folded page at the corner. Check your glass **** inside the scanner to make sure its seated in the scanner properly. The big one is the check the metal paper guides in the scanner paper path. If a guide is bend it will hook the paper and cause it to fold over.
Oct 15, 2007 | Bell & Howell B we Bell & Howell Spectrum...
Home Logo
358 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
