Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Firmware corrupt ready 2 dowaload - HP LaserJet M1522nf Multifunction Printer (CC372A)
SOURCE: error messsage on HP M1522nf
1. install M1522nf printer driver PCL5 to any usb port. 2. download latest firmware from www.hp.com 3. run firmware utility and select installed printer from drop down menu.
Posted on Jan 05, 2010
  • 123 Answers
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
Posted on Jul 14, 2010
tballone
  • 126 Answers
SOURCE: hp clj cm1312 mfp firmware
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Posted on Oct 20, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: My hp laserjet M1522nf is
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Posted on Mar 05, 2011
Ezrahite
  • 2632 Answers
SOURCE: my HP color laserjet 2605dn
Welcome to Fixya. Perform the following troubleshooting in the order listed:
1. Turn off the printer, with the communication cable still attached. 2. Manually delete and reinstall the driver: 5. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware 6. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely. 7. Power-on the printer. 8. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
HP 2605dn Firmware Update
HP2605dn Driver Download
In downloading the driver please select the operating system of your computer.
Thanks for using Fixya.
Posted on May 17, 2011
I have hp laser jet 1536 dnf the screen show message "firware corrupt ready 2 download" i can get rid of it please help-
Reload the drivers from the HP website.If it is the firmware you will need to look up how to do an update to the printer.
Jul 28, 2016 | HP Office Equipment & Supplies
HP LaserJet 2840 quit working when we were installing firmware update and power to building went off for a few seconds.
firmware corruption issue you will need to remove that printer from computer screen then reinstall it
then do firmware installation pre upgrade to stabilize(use cd or download of older version of firmware
once that's done then try the update again which won't work if old firmware is corrupted
May 17, 2012 | HP LaserJet 2840 Printer
My m2727nf try to load firmware now its giving me firmware corrupt error
Procedure Cold Reset
1. Turn off the product.
2. Simultaneously press and hold the Cancel button and the right arrow button (> ), and then turn on
the product.
3. Wait until the message Permanent storage init. appears, and then release the Cancel and right
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Let me know if this works. it should bring the printer back to factory settings.
Jul 15, 2011 | HP Laserjet M2727nf Multifunction Printer
My hp laserjet M1522nf is showing Firmware corrupt ready 2 download
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
Process:
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
Hp cm1312nfimfp (ready 2 downlod) problem
You have a printer with a firmware corruption
Try downloading the firmware from the hp.com website for your printer product number cc431a. There is a new firmware which was just released today. try downloading the firmware and sending the firmware while the printer is off,
If this does not work the formatter board is damaged and it will need to be replaced.
you can also try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
Al
Eliteprintersolutions@gmail.com
May 17, 2010 | HP Laserjet CM 1312NFI Color Printer
Error messsage on HP M1522nf MFP "firmware corrupt ready 2 download".... how do i fix this?
Sep 07, 2008 | HP Office Equipment & Supplies
Memory corruption
You need a firmware upgrade from the Philips website - this will solve the memory corruption problem.
Jan 23, 2008 | Philips 60PP9202 60" Rear Projection...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
Seeker5211
Seeker5211
