Question about Bosch 12" Compound Miter Saw 3912
Broken guard on kobalt SM2507LW
Any help on finding a replacement blade guard would be highly appreciated (e.g. compatible models from other companies, etc.)
How can I get my Seville desk fan to stop squeaking? When I called their toll-free number, they said their fans don't squeak. Talk about a company being in denial!! Their only suggestion was to take it to...
Remove the guard, remove the fan blade. Lay the fan on its back and drip 4 drops of 3 in 1 Oil down the spindle. Turn the spindle by hand about 6 turns and leave it overnight with the spindle upwards. The next day, run the fan with the blade off and see if the squeaking has stopped. If it has, replace the blade and guard.
If it is still squeaking, it is the bearing at the other end of the motor. That one is not quite so easy to lubricate and usually the motor would need to be fully stripped down, cleaned and lubricated.
Aug 24, 2015 | Dryers
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
How do I find a replacement part - Lower Guard and spring for a CSS1000
Dear Mr. Liles,
I am assuming that you are referring to the Black & Decker CSS1000 circular saw. Most parts for this tool, including the lower blade guard and spring are available online for about $20 or so (less shipping) from a variety of online tool replacement part providers.
Some companies to consider looking at are Toolparts Direct, Ereplacement parts and Sears. There are other parts suppliers as well, and I in no way endorse or recommend one company over the other. For reassembly purposes, diagrams are also available for your saw on the same sites.
Good luck in your search,
EB
Oct 11, 2014 | Saws
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 | Saws
Can't see how to remove blade guard on older craftsman 10" radial arm saw to change blades also right or left thread??
The saw I own has a thumbscrew-like shaft protruding from the area where the blade guard rests over arbor of the saw, and you simply turn that thumbscrew to loosen the clamp that holds guard on the end of the motor housing, then lift the guard up and over the blade. (After unplugging, of course.)
I don't remember which way it's threaded, but it should be pretty apparant after you take the guard off, as you can see the threads sticking out about 3/4" beyond the lock nut. This allows for the use of dado sets, etc. on the radial arm saw.
By the way, you might be able to find a manual for your saw, if you can find the model number stamped on the plate, by looking at this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Craftsman Saws
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How to tighten blade on super sawcat model 2154 , blade spins and I cant find any way to stop spindle from spinning when Im trying to tighten . Any help would be great as was my fathers saw and would still...
Usually on portable saws there is a hole somewhere in the blade guard to put a screwdriver or something through and hold the blade still while you tighten the spindle nut etc.
Hope this helps. I only have experience of a very old B&D saw which worked in this way. I now use a more modern Bosch machine which also works the same.
Jun 04, 2010 | Saws
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Bosch 12" Compound Miter Saw 3912 Logo
251 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
