Question about Frigidaire Refrigerators
Fridgedair model glrsf266j water dispenser/ice despenser not working
Ice maker works but no water or ice comes out
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
Ice maker not getting water. water despenser gets water
call chas&son,s at 570-379-0993 and they will come out the same day no less okay
Jan 30, 2013 | Frigidaire Puresourceplus Ice Water...
Kenmore 106.56666500 ice maker not working
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
29 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
