Question about Nokia Asha 306 Nv - Red
Operation failed while opening contacts
Not able to open the contact as is showing operation failed all the no. has being missing from it
5 Suggested Answers
schawlaf
  • 78 Answers
SOURCE: can't synchronize my contacts with Outlook 2007
First you have to open Outlook 2007 , and set it up with email and all , than sync the phone and in the sync settings allow access to Outlook and you will be all set
Posted on Aug 23, 2009
SOURCE: Nokia 6680, Phone start-up failed. Contact the retailer.
nokia 6300 phone start-up failed
Posted on Jul 24, 2010
  • 229 Answers
SOURCE: my N77 cannot open and
contact the service provider if it is unlocked you can try here http://www.onlinegsmunlock.com/nokia-n77/rs7wp9/
Posted on Nov 16, 2010
  • 27 Answers
SOURCE: start up failed please contact
Try to manual format your phone. Here's how;
1. Turn off your phone first.
2. Hold and press Green + Red + Camera button and Power button. Wait until phone vibrates.
3. Release Power button and wait until the selection for your location appears.
Posted on May 31, 2011
On an acer computer, in mail mode, how do I permanently delete an incorrect email address in drop down
open up the e-mail section
try this in the home tab go to the file tab ( tab next to message tab)and open new message
along the top bar you will see a contacts tab with add and check names
click on the add tab and that opens up select contacts to send e-mails to
that shows all the contacts with their e-mail addresses
highlight the address you want to change and up the top you will see a section edit contact
click on that and that contact details will open
here you can delete or change the address or add any other details for that contact
save down the bottom
Jan 24, 2016 | Microsoft Windows 8.1 - Windows
I have a Bravo 3P pet immune PIR and it says on the connector that the contacts are normally closed. Unfortunately they are normally open. Is there something that I am missing? Even the specs on the...
To work properly, this unit has to have normally closed loop circuit. With power applied, and no motion in its sight, should measure 000 ohms (plus any resistor value in series). When activated..the contact should show infinite resistance(open).
You are only missing something if you're testing it with you in the the motion area.
Trash it otherwise.
Aug 20, 2011 | Bravo Sports Dsc Bravo 3p Pir Motion...
Hi,when i connected my nokia 3110c to the pc and try to open the contacts page showing operation failed bcos of this am not able to copy my contacts.so pls give me a solution for this..
you need to download Nokia PC suite . heres the link :) then after you download it installed it after you installed den put your cellphone to your computer now :) ahehehe http://www.mediafire.com/?uixd3jnn5jg
Jul 09, 2011 | Cell Phones
My nokia 7210 supernova is showing operation failed plz help
Remove the battery and keep aside, remove the memory off. Now replace battery and see if the phone reboots , if not there can be a software issue and you might have to contact Nokia care to reinstall.
Sep 28, 2010 | Nokia 7210
Operation failed
You may have installed the application on your memory card and it has problems or your phone has contacted a virus.
Contact your phone engineer.
Apr 03, 2010 | Sony Ericsson K800i Cellular Phone
Mobile not open "phone start-up failed. contact the retailer"
press and hold SEND key+* key+2 key when you switch on the phone
Jan 18, 2009 | Nokia 6630 Handheld
Contact links (Outlook 2000) missing in Outlook 2007
Open Outlook 2007 (don’t laugh, but I need to clarify that you’re in Oultook 2007), and Tools>Options, /Preferences tab, /Contact Options (b) and check “Show Contact Linking on all Forms" box, /ok, /ok.
This information was put online by Jennifer Kershaw. I do not use outlook 2007 but found this answer by surfing for you. I hope this helps.
Sep 30, 2008 | Microsoft Office Professional 2007 Full...
Lost contacts on my Philips VOIP Skype phone
I had this same problem... If you use Microsoft Outlook for emails, then this might be the solution: Open Skype and click on View, and untick the 'Show Outlook Contacts'. Hopefully this will cull the list of contacts and will enable the Philips voip phone to view contacts again... Perhaps it's because the Outlook contacts are vCards - something which the Philips phone can't recognise?
Jul 25, 2008 | Philips VOIP8411B/37 IP Phone
Missing manuel Code showing - F 2 -
hi,
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
Nokia Asha 306 Nv - Red Logo
117 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
