Question about Canon EOS Rebel G 35mm SLR Camera
How to replace clock battery in eos rebel ll
Camera not powering on. Tried two new batteries and no results.
    Top Expert:
  • Canon Master
  • 6,702 Answers
Your "clock battery" is just a very little rechargeable battery, that will charge as soon as you put in a fully charged battery in your camera. You should wait for at last 12 hours, before you remove the battery. and the little battery can keep the clock running for several days.
Everything that is in the camera, only can be replaced by a skilled electronics engineer. The best thing you can do is contact a certified Canon repair centre and ask what it will cost to build in a new clock battery. But before you think it is a clock battery, make sure your battery is still in working order. Ask around if anyone you know has the same camera and borrow a charged battery for a few moments, to make sure it is not you camera battery.
Posted on Apr 25, 2014
  • 17 Answers
SOURCE: how to replace the door latch on a canon rebel eos ti
The cameras film door has a very small phillips head screw inside the battery doors hinge. Its a pain to take out & replace if you hands are shakey for this screw is so small. Also installing the replacement hinge would be a little harder to install tha removing the broken one.
I hope this information will help you. A camera shop should be able to do it for free if you maybe purchase some items there. Most shops which are very small and privately owned shops will do this for you
Posted on Mar 07, 2009
pontelemon
  • 538 Answers
SOURCE: Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Posted on Apr 09, 2009
  • 685 Answers
SOURCE: My canon eos rebel k2 will not turn on even with
Dirty contact in the battery compartment, bad power circuit, bad switch etc. Too many things to be able to fix in this forum. Send it in for service or buy another used one, that may cost a lot less than getting yours repaired.
Posted on Nov 24, 2009
ftw1952
  • 10319 Answers
SOURCE: canon eos rebel x won't turn on, even with new
Bad capacitor or circuitry
Posted on Jan 01, 2010
  • 302 Answers
SOURCE: my cannon eos rebel x 35mm wont take pictures on
Your AF module needs to be replaced. Or maybe the mirror part that bounces light to the AF module.
Another possible issue is light. The AF sensors need a certain amount to light to be able to see if its in focus. Some lenses don't allow that much light to pass, so the sensors can't focus the lens. Try a lens that passes more light, like the 50mm f/1.8 or point your lens at a very bright scene.
If increasing the light level doesn't solve it, it needs repair. You might check Ebay for a "parts" Rebel to have spare parts for your good one.
Posted on Jan 26, 2010
Why With a new battery, there seems to be no power on my canon EOS digital rebel xt?
Did you remove the USB cable? As long as there is an USB cable in the camera, you can't power it up.
Then you still have to check if the battery is still in good order. Batteries do have a limited time of life. And you only can be sure it is charged, when it works in another (same model) camera.
May 14, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Check the battery cap and the contact springs for any sign of battery leakage that may be shorting out the batteries. Clean with a hard eraser like a pen eraser. Make sure batteries are good, and are inserted properly, and that the battery cap is not damaged. Make sure the metal plate is in place on the battery cap. The back up battery is on the back of the front flexible circuit and you have to remove the mirror box to get to it. This is a complicated proceeedure that requires specialist knowledge and is not user servaciceable.
Apr 19, 2014 | Canon EOS Rebel G 35mm SLR Camera
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
My S9600 was left unused [batteries left in camera] for several months. Now it will work fine with the mains adaptor, but is completely dead when on battery power. Have tried new batteries [rechargeable...
Sounds like corrosion on the battery contacts. I have seen battery contacts with a thin, transparent coating that came from leaking rechargeable batteries- doesn't look like the usual green crud, but it stops electricity from getting through. Try giving the contacts a scrape- you will need a long thin screwdriver or something of the sort.
Dec 01, 2010 | Fuji Finepix S9600 Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
When I turn it on the power light blinks several times and the camera dies. Everytime. Tried new batteries etc...
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare CX7430 Digital Camera
Canon EOS Rebel G 35mm SLR Camera Logo
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
