Question about Acer Aspire 5100 Notebook
How to create a boot up disk for acer on window 8
When I start up the window went blank
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
zohail
  • 1223 Answers
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Posted on Mar 02, 2009
luis356
  • 53 Answers
SOURCE: acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Posted on Jun 02, 2009
  • 597 Answers
SOURCE: Acer says this when i sign-on:
It's not able to see your hard drive. Something may have changed in CMOS about the boot order. You should enter the bios and see if it sees your hard drive. Then go into advanced boot options. First boot object is usually set to CD Rom for setting up operating systems and the second boot device should be your hard drive. Third boot option can be left at none or a floppy drive if you have one. If the bios is seeing your hard drive and it is set as a boot option then the drive may be damaged or system files have been lost. If there are valuable files on the hard drive and it is failing then you might consider taking this to a professional and trying to rescue your files asap before the drive deteriorates any more than it is. You can also try some repair options from booting off the Window's CD but beware that formating your drive is one of the options and this will erase any files you have on the drive.
Posted on Nov 19, 2009
sparky1500
  • 1066 Answers
SOURCE: I need to create a boot disk for my ACER Aspire
no, xp cannot create the start-up disk. it can only be created on the same machine and in the same os as it is intended to repair.
Posted on Dec 27, 2009
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Forgot my password
If i forgot Acer password, what should i do?
Step1: Download Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to reset forgotten acer password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Jul 10, 2012 | Acer Aspire 5349-2592 Intel Celeron B800...
What is the empowering password to reset acer aspire 5610
I don't know what is the empowering password of Aspire, but I know how to reset windows password when forogot it.
Two ways:
One, reset disk, if you have created before.
Two, windows password reset tool .
Jun 24, 2012 | Acer Aspire 5610-2328 Notebook
How to unlock administrative password on acer laptop
I also forgot my Acer windows password last week.
I searched the solutions on the internet, at last I unlock administrative password with a tool called Windows Password Reset.
It just spent me 5 minutes to reset admin password.I found this usefull, you also can have a try.
Jun 10, 2012 | Acer Aspire 3502WLCi Notebook
Acer veriton X275 recovery download
You can make a recovery disk by the following steps,
Step1: Download Smartkey Windows Password Recovery from SmartKey website.
Step5: Start to remove Windows password with the burned disk.
Jun 07, 2012 | Acer Veriton X275 PC Desktop
Do not have password how can i reset the computer
If you could use another computer which could download from Internet, you can create a windows password recovery disk. Third party software windows login recovery could create such a disk. Only four steps:
Step 1: Download Windows Login Recovery and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
Aug 14, 2010 | Acer Aspire 3680 Laptop
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
I need to know how to reformat my acer extensa 4220. I have no boot disk and I have a virus that is not allowing me to see my system information or MYcomputer and so forth
first create a boot disk.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
You Will Have your own Boot Disk.
Backup Your Data.
Boot With the help of BootDisk.
Load a new XP.
Virus Scan All the Drives and Data.
Sambeet
Sep 19, 2008 | Acer Computers & Internet
Acer Aspire 5100 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
