Question about Raymarine A57D GPS Receiver
A57D GPS/Sonar won't take a fix
The unit uses a internal antenna and is in the open. It has previously been o.k.
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Page button does not work.
Same problem, I found out how though. If your willing to lose your waypoints like I was, turn the unit on, then off. Hold the Zin and Zout buttons down and and then hold the power button down, when you get to the map, release Simultaneously and it will reset and work. and questions email me at burton_rider11@hotmail.com. Hope this helped.
Mar 26, 2009 | Eagle Fishelite 642c Color Fishfinder Gps...
Internal GPS antenna won't turn off
I have the same problem after unit dropped on tile floor! Everything works well except gps turns on when I power up regardless of antenna position. Tried various resets -no fix.
Jan 19, 2008 | Garmin iQue 3600 GPS Receiver
Raymarine A57D GPS Receiver Logo
15 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
