Question about Compaq Presario V5005us Notebook
HAve a Compaq Notebook PC V5005US that won't turn on. Was working when I turned it off. Only one light on in front the IDE Drive light and that is all. It has Windows XP. That is about all I can tell you.
  • 674 Answers
CHECK THE POWER BUTTON.. IF THE SAME PROBLEM.. NO POWER ON THAT IS BOARD PROBLEM POWER REGURATOR OR IC SOME PROBLEM.. BRING TO QUALIFIED TECHNICIAN
Posted on Jun 19, 2009
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
Can you get me an audio driver for my Compaq Presario V5005us
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jul 30, 2011 | Compaq Presario V5005us Notebook
When I press the power button, nothing happens...this was after I ran a test on the hard drive and it said that no IDE was found. Now it is not even powering on.
Hi
i would remove the hard drive from the bottom of the laptop give the ide part of it a blow
then replace making sure of a firm fit
then make sure the laptop is plugged into the wall socket and turned on and that the power light is showing up on the front of the laptop
and try again
if that dont work
try this
power up and at the same time keep pressing the F8 key then choose
last know good configuration and windows will try to restart itself
hopefully it will
Feb 02, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a compaq presario v5000 but the wireless switch cannot be turn on
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Also
have you gone into your device manager and seen if the wireless network device is turned on/enabled?
Nov 15, 2010 | Compaq Armada M700 Notebook
Computer locked up had to turn off with power button
To narrow down on the issue, try connecting some external monitor to the system and see if it works.
If above doesn't work then the fault is with the motherboard, else the screen is faulty.
Either of the two motherboard or monitor is faulty. Try contacting the service station or vendor.
Apr 24, 2010 | Compaq Presario Notebook
Compaq presario sr1800nx won't turn on
Check the jumper settings on the DVDRW. Depending on IDE location, you need to set the jumpers accordingly. If you have the main system hard drive on the same IDE channel as the DVDRW, set the jumpers on the DVDRW to slave, if that don't work, set them to Cable Select. I'm assuming it's an IDE drive and not SATA.
Dec 30, 2009 | Compaq Presario SR1800NX Desktop PC
Have a Compaq Notebook V5005US PC that won't turn on. The only light showing on the front is the IDE light. No battery light. Don't know what might have happened? Was working when I turned it off.
Unplug the power cable then remove the battery and let it sit out for a while. Then put it back in and try it. Sometimes the battery can cause issues. not saying this is the absolute fix, but it's a starting point. Post a response if this doesn't help and we can take the next step to try and troubleshoot it.
Jun 19, 2009 | Toshiba Satellite Pro 490CDT Notebook
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Compaq Presario V5005us Notebook Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
