Question about Imperial IFS-40 - Gas Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide
Imperial ifs 40 pilot light on but burners won't ignite when thermostat turned up
4 Suggested Answers
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: Burner will not come on
need tochange termal couple
Posted on Jun 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Posted on Aug 01, 2012
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Hello,I have a Imperial IFS deep fryer S#06301407 .We had a pinhole repaired in tank.I know that tank was removed prior to repair .Unit did work fine other than leak before tank repair.After lighting pilot...
You can use a jumper wire to test the valve. The voltage is LESS than 1 volt so do not worry. Imperial fryers usually use a robershaw gas valve. the 2 outside terminals...left and right.... are where the thermostat connects. Using a jumper wire after the pilot is lit will tell you if the valve is good or if it's the thermostat. You can also use a multimeter and check the continuity of the thermostat.
Tom
Jun 08, 2010 | Imperial IFS40 Deep Fryer
Jun 01, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Imperial IFS-40 - Gas Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide Logo
116 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
