Question about Imperial IFS-40 - Gas Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide
How to turn on an imperial gas valve
How to turn on gas valve
Gas valve wich way do I turn knob to install my Kenmore elite dryer
If a gate valve: Turn the valve clockwise to turn OFF the gas.
If a ball valve: Turn the valve handle perpendicular to the valve body to turn off the gas.
Install the dryer. Attach all lines.
Turn gas on.
Using a soap/water combination, spray all gas lines to check for leaks. If any bubbles form, then turn the gas off and seal all leaks.
If you do not know how to perform these functions safely, then pay a qualified technician to prevent a gas explosion.
gate-oqy5fah40apqzze5k2tsaxfy-2-0.pngGate
ball-oqy5fah40apqzze5k2tsaxfy-2-2.pngBall
Feb 05, 2018 | Kenmore Dryers
Imperial oven will light but will go off when you turn on more than two Cooker burners. What could be the cause ?
this is usually and indication of a gas issue. either a gas pressure issue or the cut off valve not open all the way, or the hose connection is not completely on if it is a snap-on type.
Mar 01, 2017 | Imperial Ovens
Jandy Lite 2 is showing FL4 My igniter is turning red but no flame. DO I hve a gas problem?
see if you have 24 volts to the brown and yellow wires on the gas valve if wires are loose it wont work either if no voltage to gas valve bad pcb board if voltage to the gas valve bad gas valve
Aug 31, 2014 | Jandy Pool & Spa
Rv heater keeps running
Try cycling your disconnects a few times. Turn off the propane at the tank. Turn on the vent fan. Then turn on the furnace. Yes' I said turn off the gas and turn on the furnace. As the furnace tries to ignite "you will hear the spark" SLOWLY open the gas valve. I say slowly because the tank valve has a safety feature that stops the flow of gas if it is going to fast. By opening the valve slowly the gas will pressurize the line and the valve will stay open.
Here is the reasoning behind this. If your refrigerator, water heater or anything else gas was turned on while the gas valve was off the pressure left the line. When you turned the gas back on there was a rush that let the over sensitive safety valve kick out.
Some models have an electric safety valve connected after the regulator and it is controlled by the gas leak detector. If that detector is set off by anything..hairspray, Frebreeze, bug spray, silicone spray etc... it will turn off the gas at that electric solenoid. Clear the offending spray and reset the detector.
Apr 13, 2012 | Heating & Cooling
I JUST BROUGHT THIS IMPERIAL DEEP FRYER AND I WANT TO CHANGE FROM NATURAL GAS TO PROPANE GAS.
You will need a conversion kit from natural gas, most of this kit contains gas valve spring, burner and pilot orifice. Check the nearest authorized dealer in your area and ask buy the appropriate conversion for your fryer.
May 28, 2011 | Imperial IFS40 Deep Fryer
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
WE HAVE A NUMBER OF LPG IMPERIAL IFS40 FRYERS WITH A VERY LARGE FLAME ESSESIVE FOR THE UNIT FLAMES BURNS AND EXTENDS AT THE BACK OF THE FRYER INTO THE FLUE . WE HAVE CHECKED THE CORRECT INJECTOR , CORRECT...
check the burner orifice and gas valve spring kit if it is suited for propane use.remove carbon build up inside the fire tubes.check also if the gas pressure is correct.
Mar 11, 2011 | Imperial IFS40 Deep Fryer
I have a Reliance 501 Gas that is leaking water from the bottom. How do I shut the water off and how do I turn off the gas
There should be a valve on the cold water supply entering the top of your heater. This may be a gate or globe valve with a circular handle on it. If you have this type of valve then turn handle clockwise,to the right to close it. You can check output on hot side of faucet to see if valve is working. There may be a ball valve with a straight handle on it. To shut this off push or oull handle till it is at right angle to valve. As a last resort you may have to shut off water supply to house.
On the gas start out bt shuting gas off at control knob on top of gas valve. It should be marked on off and pilot. Turn to off. Now check on incoming gas line for valve to shut gas off before it gets to gas valve. This valve should have a raised flat section that you can close with a adjustable wrench.Turn till it is at right angle to pipe and you should be done. Turn to right to shut it off. Hope this helps you. Thanks
Dec 23, 2010 | Reliance Natural Gas Water Heater Control
Hello,I have a Imperial IFS deep fryer S#06301407 .We had a pinhole repaired in tank.I know that tank was removed prior to repair .Unit did work fine other than leak before tank repair.After lighting pilot...
You can use a jumper wire to test the valve. The voltage is LESS than 1 volt so do not worry. Imperial fryers usually use a robershaw gas valve. the 2 outside terminals...left and right.... are where the thermostat connects. Using a jumper wire after the pilot is lit will tell you if the valve is good or if it's the thermostat. You can also use a multimeter and check the continuity of the thermostat.
Tom
Jun 08, 2010 | Imperial IFS40 Deep Fryer
Imperial IFS-40 - Gas Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide Logo
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
