Question about Dyson Vacuums
Dyson brush spins and then stops - Dyson Vacuums
louislevel_2
  • 374 Answers
SOURCE: The brush stopped spinning on my Dyson upright
hi there'
common possible defective is that motor is not functioning,several factors can be check if you have a knowledge on electrical and motor
circuit you can easily diagnose your problem on your vacuum.
check the switch by your multi tester,if there is a continuinity resistance using multi tester.if no continuity replaced switch
check the carbon brush of the motor if worn out, replace two pcs. of carbon mounted inside the motor casing
you can check also the continuity of electrical cord and plug.replace if if plug and electrical cord is defective.
finally the motor has winding coil,at both end of coil of motor check the continuity,there are two coils of the motor.if burn out replace motor w/ two pcs. of carbon brush.
besure to unplug the vacuum before doing
this and this should be done by qualified technician on your service center.have a nice day.rate my fix.thank's a lot
Posted on Jun 11, 2009
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
  • 53 Answers
SOURCE: dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
Posted on May 31, 2010
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC24 brush no spinning.
    Hi, it's Jack from Dyson.
    You may find it useful to try pressing the button in as far as it will go - this should resolve this issue for you.
    However, if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), and we can run through some checks with you over the phone.
    Kind regards,
    Jack
    Posted on Jun 07, 2011
    Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
    I can think of three things that could be wrong.
    The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
    The internal drive belt is worn, or the nylon bush that it runs on.
    The clutch is worn out.
    The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
    If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
    Sep 13, 2015 | Dyson Vacuums
    Carpet brush does not work on dc26
    With this model, the most likely cause is that the brush has become clogged and won't spin freely. Unplug the unit and test spinning the brush bar by hand. If you really can't get spin, follow instructions like these (
    Dyson DC26 DC35 DC36 DC38 DC44 DC45 DC47 Clearing the brush bar Official... that are straight from Dyson). Make sure you get the very ends fiber-free. It should spin better now.
    Good Luck!
    Jul 07, 2014 | Dyson Vacuums
    Dyson dc 24 brush works intermittently
    Broken wires in the side of the machine
    Dec 27, 2013 | Dyson Vacuums
    Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    The brush on my Dyson DC-14 wont spin
    hello, have you checked to make sure you have nothing wraped around the brushes ? also it sounds like your belt needs to be replaced.
    Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
    Dyson Brush Bar Always Spins
    Take off the brush cover and check that the suction orifice is clear. Also check the rubber flaps at the bottom of the hose/handle holder is correctly positioned.
    Feb 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Vacuums Logo
    260 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
