Question about Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Gas Dryer MDG8600Aww sometimes works
My gas dryer seems to work the first time you set the timer and do a load of clothes, but then will not work after that 1 load. Maybe 12 hours later you can do a second load. It's like it needs to cool down and not run for a long time before next load. The timer will not even move around and work after that first load in the '' More Dry, Permenant Press, and Air Fluff'' settings.
You can run a second load, the timer will not move but the dryer will run forever and no heat. If I move the timer manually really slow and get lucky, I once in a while can catch the spot that turns on the heat and the dryer will heat up for a short time, but the timer will not move, the heat cycle finishes, and then won't move anymore so the load of clothes will not finish drying.
Is there a part that allows the timer to run properly ? like a control unit that allows the timer to move ?
I repalced the timer, but same problem with new timer. I returned the timer, got another one, and it does same thing, so 3 timers don't seem to be bad. The timer will only work once no matter which timer I tried, timer moves and runs, but after one load thats it until later in the day. Later in the day it's like the machine has had enough of a break, and it will run again for 1 load. If I set the timer to just run like for 60 minuites, the timer will move in that mode, but no heat. If I set the timer to Permenant press, or delicate, or '' More Dry'' modes the timer does not move after the first load is done.
Your suggestions will be appreciated.
Mark Ward
  • mark_ward160 Jun 19, 2009
    The model dryer that came up is not correct. My model is MDG8600AWW. The reply I got is just a web site with part # 158 and it is a drive motor. What is this motor ? My dryer motor to turn the drum works fine and runs as lomg as I allow it to run. Is this drive motor different than the motor for the drum ?
    If so How do you replace the drive motor ?
    Thank You,
    Mark Ward
    Mark
  • 3,600 Answers
Try this look at the door switch and see if it is loose if it is tighten it, if not check the wires on the button that starts the dry cycle, if it's loose replace it, if that don't fix it post again and I will answer if it is still not locked.
Posted on Jun 19, 2009
  • 495 Answers
Click here
Hope it will solve your problem.
On my gas dryer... timer and knobs all seem to be working. But it is not providing any heat...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 27, 2011 | Maytag LSE7806A Top Load Stacked...
Maytag Gas Dryer, 18 years old. Vents are clean through the entire system. The thermal igniter/coupler glows for a few seconds and sometimes ignites the gas and it's fine. However, sometimes it glows and...
Hello- You will need to have the Coils replaced, they are not holding the valve open consistently, it is a fairly common issue and presents itself as you describe. The parts are fairly inexpensive but you should have a Tech out to change them for you. These are great dryers and I would have the Tech look through it while it's opened up...drum wheels and belt should be checked for ware. Hope this helps, best regards.
Sep 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Maytag Gas dryer not heating, Model #MDG8600AWW
Called Maytage directly, information is free. Thanks anyway
Jan 13, 2010 | Maytag Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat, exhaust clean and gas flow good.
I hope this helps U
copy n paste http://www.partselect.com/ModelFrames.aspx?ModelID=153823&ModelNum=MDG8600AWW&ManufactureID=1&Selected=51311&Position=6&mfg=Maytag&Type=Appliance&Mark=6
let me know if this works for U
"Was this helpful?"
May 09, 2009 | Maytag MDG2706A Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
