Question about Chateau St Jean Sonoma County Fume Blanc 2008 750ml
How long can you keep a bottle of fume blanc? (unopened)
SMELLY EXAUST FUMES, NO EXAUST FUME COLOR
I am assuming that it smells like sulfur or rotten eggs. This is a bad tank of gas. Put a bottle of octane booster in the fuel tank and don't buy cheap gas again.
May 25, 2014 | 2005 Scion xB
Where and who are antique Whiskey collectors/Buyers
How cool is that! Here is a link to a whiskey collectors forum. You can post about it there. You can probably find a buyer there, or at least someone to appraise it and tell you what it's worth.
Feb 13, 2013 | Wine & Spirits
What is cognac and how is it made?
Cognac is a superior type of brandy created from white grapes (Ugni Blanc) produced strictly in a region of Western France.
Grapes are harvested in late September and are pressed and fermented, then double distilled. By law, the distillation process must end by midnight on March 31 the following year. After which, the distilled liquid is blended, aged and bottled.
Visit this site for more information about the process of making cognac -
http://www.cognacnet.com/cognacabc.htm#%23how
Feb 05, 2013 | Wine & Spirits
Where are some of the best Sauvignon Blanc wines produced?
The most classical and popular Sauvignon Blancs are manufactured in Bordeaux and the Loire Valley. The brands of Sauvignon Blanc that come from these regions are often referred to as Sancerre and Pouilly-Fume. Some other parts of the world that are well-known for good quality Sauvignon Blanc wines include South Africa, certain parts of California and New Zealand.
Feb 03, 2013 | Wine & Spirits
The temperature hand rises almost to hot
This could be caused by any number of different things or a combination. - Failing thermostat - Slipping fan belt - Thermal sensor bad for gauge or fan control - Radiator clogged with dirt and debris - Bad or failing pressure cap on overflow bottle - Failing head gasket; this will normally show contaminants in oil or coolant and possibly noticeable exhaust fume odors from an open overflow bottle.
Jun 05, 2011 | Chrysler PT Cruiser Cars & Trucks
Keeps loozing walter but no leak no walter in oil
You could have a head gasket failure between a combustion chamber and a water channel. Sniff the fumes from the expansion bottle to see if they smell of exhaust fumes. This failure should also produce bubbles in the expansion bottle if true.
May 03, 2010 | 1997 Jaguar XK8
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Chateau St Jean Sonoma County Fume Blanc 2008 750ml Logo
95 people viewed this question
Top Chateau St Jean Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Chateau St Jean Wine and Spirit Expert? Answer questions, earn points and help others
