Question about Garden
Powercraft chainsaw 45cc - Garden
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: I have a powercraft chainsaw, do you know the
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Posted on Mar 05, 2009
dontbother10
  • 2220 Answers
SOURCE: Does anyone know the carb. setting for a Homelite
Start 1.5 CCW from lighty seated then do as the link suggests.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Posted on Dec 28, 2009
  • 12 Answers
SOURCE: fuel to oil ratio.
40 to 50:1.
Posted on Jun 13, 2010
jcameo7270
  • 675 Answers
SOURCE: poulan 45cc chainsaw will start
Sounds like the low speed fuel adjustment is out of whack....you can reset it by turning it in all the way clockwise...then as a starting point, turn it out 1 and 1/2 times, start the engine and slowly adjust the screw until the engine starts to choke out..when this occurs, turn it back in until it starts to choke again...then you need to set it somewhere in between to find the "happy medium"....thew high speed screw is adjusted after you get the engine idling properly...if you haven't messed with this then I wouldn't worry about it..unless you have poor high speed operation, then you will need to set the high speed screw...the object here is to obtain the best low to high speed throttle...if , when you throttle up the saw, the engine bogs or goes to high speed slowly , here is where you adjust to get the best throttle response...use small increments until you achieve the desired response
Posted on Apr 26, 2011
Testimonial: "Thank you so much! I read this to my dad via phone for him.. This was for my dad helping my uncle in Cape Breton.. Thank you and he understood... now "
I have a fuel leak on my husqvarna chainsaw 345
Where is it leaking- gas cap or bad fuel line.
Oct 05, 2014 | Garden
CS4518 chainsaw viper engine
Check the compression. It should be 100 psi or above.
Aug 27, 2013 | Earthquake CS4518 - 18" 45cc Consumer Gas...
Manual for 330 homolite chainsaw
losen the nuts for the clutch cover and tighten the screw on the side of the bar
Mar 23, 2012 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
What is the gas ratio for a 2003 18" makita chainsaw
Hi lereana pete
Use a 50:1 mixture
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 09, 2011 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
I have a powercraft chainsaw, do you know the petrol / oil ratio ?
Mar 05, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
