Question about Sabre LCT371BKA LCD TV
Pc connection unsupported
Compaq 621
I think the error 104-unsupported wireless network is an error happen to be meant to your broadband or net connect. You should try to enroot the error or concern your broadband retailer.
http://mhelpdesk.com/field-service-management-software/
Sep 02, 2013 | Computers & Internet
"Error Message: 104-Unsupported wireless network
Go to the network connection or network and internet connection in the control panel. The pc maybe picking up wireless connection from other devices around you. You can go there and remove them.
Jun 28, 2011 | HP Compaq Presario V2000 Notebook
How to connect in my pc by samsung pc stdio
Installation procedureFirst of all you need to have Samsung PC Studio installed on your computer. To download it, go to Samsung Download Center and choose the model name of your mobile.Installation using Samsung PC Studio:
  1. Connect phone to PC
  2. Run Samsung PC Studio if not running
  3. Open file manager (Click "Manage Files")
  4. Copy .jad and .jar to "Other Files" folder on phone. (You can download these files from our website)
  5. Disconnect phone and go to "Other Files", run .jad file to install and run the application.
If a message "Unsupported file format" appears, then it means that installing applications from PC is blocked in your mobile. In that case the simplest solution is to install per WAP. There are also ways to bypass this limitation and unblock the mobile. Try to search Google for eg. "C3300 Champ install jar" (witnout quotation marks) or "Samsung GT-C3300 Champ Unsupported file format"
Jan 11, 2011 | Samsung GTC3300 Cell Phone
Trying to connect my pc to tv have a message on screen of tv saying unsupported signal adjust your pc output.how do i do that
Your TV you are trying to connect to the pc may not be compatible with the connecting device or the connection output to the TV is incorrect.
Please provide more information as to you issue such as :
a. model number
b. year manufactured
c. Has the manual to the TV been viewed
d. PC information needed (out puts/inputs)
Jun 21, 2010 | Computers & Internet
Monitor does not work when connected to desktop . if i plug it into a laptop it works
Most likely the display resolution set in the desktop is unsupported. Boot in Safe Mode and change it to something that will surely be supported like 800x600. Next boot normally and try to increase it step by step till you reach what you want - if by accident you select another unsupported resolution and the screen goes black just wait 15 seconds an the pc will revert to the old setting.
Jun 16, 2010 | HP Computers & Internet
An unsupported memory module was detected a
Sounds like the Memory Ram that you tried to install went haywire. Take it out and make sure this ram is compatible.
Apr 10, 2010 | Dell Latitude C810 Notebook
Unsupported media file. important
try connecting your phone to your pc through usb, and copy that pic to your pc to view it
Mar 16, 2010 | LG KU990 Viewty
I am trying to hook up my hp laptop to my sony bravia tv and when i make the connection the laptop monitor goes black and the tv says unsupported signal. I then have to reboot the laptop to get the screen...
"Unsupported Signal" means that your laptop is probably set to a resolution or refresh rate that yoru TV doesn't support. You will need to go into your Laptops video settings to make them match what your tv will display.
Jun 03, 2009 | Computers & Internet
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Unsupported Signal
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
May 13, 2008 | Toshiba TLP S30 Multimedia Projector
Sabre LCT371BKA LCD TV Logo
10 people viewed this question
Top Sabre Televison & Video Experts
Electro Med Services...
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
