Can't load win8 setup
0x000005D error. It said "computer needs to restart". When I restart, it shows the above error again. I use virtualbox
    Problem Solver:
  • 5 Answers
  • Joe Dai
    Joe Dai Aug 15, 2014
    Thanks
    Problem Solver:
  • 24 Answers
Your operating system is missing startup file, so the easy way is to insert main operating system CD in to drive and run step up , you need to be in safe mode before you try this.
good luck
Posted on May 08, 2014
In the middle of installing Windows 98 in Virtualbox I get a message Application Error SUWIN caused an Illegal Instruction in module VGA.DRV at 0001:011B. How can I fix this error?
Is this occuring during the install?
If this is the case, try this (it will be useful to know when the problem occurs):
Go to the VM Settings
Go to System
Go to Acceleration Tab
Uncheck Enable VT x AMD V
I hope that helps.
If not, there is a guide on the virtualbox forums here
Which I would suggest trying to run through instead.
Dec 22, 2012 | Microsoft Windows 98 for PC
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
I have XP with Service pack 2. On startup I have been getting warnings on OX0000007F. Now the computer won't start. It gets the Windows XP page with the bar in it and then goes to "setup...
The issue is some of the WinXP components are not getting loaded.
Solution
When computer starts, press F8, chose option Start in Safe Mode
let the PC come to the Desktop screen
then when stable, shut down and restart.....
if the solution above does not work then you may have to re-install WinXP again. you need to use a WinXP CD and do a Repair of Windows when the install feature askes for it....
all the best
Nov 24, 2010 | Computers & Internet
I have formatted my system but whenever i am starting it, its asking for bootable device. After formatting it again it loads all set up file, then it reboots the system but after rebooting it again loads...
after it loads al setup files and it will say something like the computer needs to restart press enter to restart now or it will automatically restart in (so many seconds will be displayed) So as it is restarting it will flash up something like press f2 or delete or some other key to enter setup ( if you miss what key it says just hold down ctrl-alt-delete and it will restart again. So after entering setup, you will be able to scroll through the settings and find one that will allow you to change the boot device sequence and just set your hard drive to be the first boot device. It sounds like right now the computer is set up to boot from the cd rom drive first and so when it restarts then it will load the windows setup files again like you said. I know it's stupid and nobody tells you that is what you have to do , you kinda have to figure it out on your own.
Aug 01, 2010 | Acer Computers & Internet
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
When i shut the notebook down and tryed to load it back up it will not load it gets to windows is staring and then restarts the process
Hi there!
Your computer may have an error that is causing the computer to restart, Try this one, when you turn on the computer start pressing f8, then advance boot menu should come up, after that select, disable automatic restart then the computer will start booting to windows then it should display the error, if it still stays on the screen q/o showing anything, do the f8 process again and this time select safemode.
Hope this helps!
Jun 01, 2010 | Computers & Internet
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
Computer only states load error
press f8 during restart then choose last known good
if still can't load f8 again then safemode do a disk defrag and then restart
if you still get same error or cannot get on let me know so i can try another solution
don't forget to rate
Feb 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
