Question about Technics SU-G75 Amplifier
Only one input resultes in an output
Only one input results in an output the one that works is EXT John Hope
    Problem Solver:
  • 8 Answers
John , Those units are KNOWN to have faulty switches. the most common switch it the TAPE MONITOR . try pressing it on and off several times to see if your other channel will come back on. If it does , even for only a second , you should try to spray a good quality contact cleaner such as De-Oxit cleaner. It should fix ya right up.
Posted on Apr 23, 2014
The sound from my tv will not play through my surround sound.
Make sure that you have your receivers input selector to the correct input that you plugged your tv into. Try plugging the tv output into the working input that you have for the dvd. If the tv still does not work, and you are using a working input, then clearly, there is no workable signal going into the receiver. In tv menu check the audio output format.
Some tv sets output their audio signal in digital format. If you plug that into a receiver with an analog audio input it will result in silence.
Apr 02, 2014 | Audio Players & Recorders
The remote or Aux input does not work on my Galls Street Thunder xs100. I hooked up a switched ground lead, no result. I hooked up a switched positive lead, no result. Any ideas??
What do you mean you hooked up a switched lead? There are inputs for voltage, outputs for speaker, a connection for the horn ring and a set of terminals to hook up the output of a radio to.
Sep 15, 2013 | Radio Communications
Do you plug the sub woofer outputs to another amp?
Yes, for best results. Your subwoofer should have a seperate amplifier because it has low pass filter that produces low frequency signals. It is done by connecting the sub woofer output to the input signal of the amplifier and then connecting the output signal to the subwoofer speaker terminals. Hope this helps.
Jul 01, 2011 | Car Audio & Video
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
No component video output.
Check that the input video mode for s-video inputs is AUTO or S-VIDEO.
setup>manual setup>input setup>input video mode.
Jul 20, 2009 | Denon AVR-2105 Receiver
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Hot Drive - 2 Responses, neither worked
Hey, it seems you have a faulty inclosure.
Sep 03, 2008 | Computers & Internet
Mitsubishi CS 13101
EXT means external input,i.e.from an outside or alternate source.
That source could be a DVD / VCR , cable box, video game,etc.
2) New dvd/vcr recorders allow A / V inputs only,usually obtained
from a source box ( cable or satellite ) They do not have coax cable input/output,also known as RF in/RF out.
3)The dvd/vcr manufacturer expects the consumer to upgrade equipment periodically.If your TV or A/V receiver ( surround sound) has a video monitor output,problem solved!
Hope I helped you ......T.
Oct 18, 2007 | Televison & Video
Blank screen on Digital In
Go into the service menu using the remote (hit the sleep timer, then video status and display at the same time), go into the status menu #2, then power off the tv. This will reset the HDMI port. If your sitll experiencing the issue, probably a dead board.
Nov 19, 2005 | JVC HD-52G786 52" Rear Projection HDTV
Technics SU-G75 Amplifier Logo
48 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
