Question about Tatung V20CCBX-U02 Television
How to setup tv with set top box - Tatung V20CCBX-U02 Television
  • 66 Answers
Rca to rac or hdmi to hdmi cables then select av on the tv to which ever one you connect it to eg avi av2 av3 or hdmi 1 hdmi 2 etc
Posted on Apr 19, 2014
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
FIOS cable /set top box doesn't turn Samsung tv on or off or adjust volume
Check it by setting with an other code to your device brand, from the setup code list of the remote control. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 14, 2013 | Samsung TV Set Top Box Remote Control
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
How do I get the closed caption to turn off? It's been on for weeks, all the time. I've tried to turn it off from the remote: I press "menu", scroll down to "features" , go to...
What is the Source of the video? The captions menu item that you found will only enable/disable the closed captions from select sources, including your TV antenna or RF cable. For other sources (particularly HDMI), you need to disable the captions using the options for that source.
On my IPTV (fiber-optic TV) box, that requires entering the setup menu with a passcode from my provider. Next I go to the Hardware menu and find the captions option under the Audio sub-menu. On one satellite setup, I found that a secondary set-top box could only get the closed captions if they were enabled on the primary set-top box. Thus disabling the captions required accessing the set-top box's menu from the correct TV.
I hope this helps. Please add a comment with your TV source (make and model), if you'd like help finding the CC option menu for that device.
(With a slightly different IPTV set-top box, the included remote had a CC button that worked without needing the passcode. The current one doesn't.)
Jan 21, 2018 | Philips 42PFL3704D LCD TV
I have lost my remote control for my philips tv. i have a philips set top box with a tv option. i have read up and know that the remote for the set top box can be setup to control the philips tv. i had...
generally you push the "tv" button on the remote first before using any other buttons unless there are dedicated tv buttons. if the remote is preprogrammed for other makes/models then the list of codes will be found in the STB handbook under remote programming.
Aug 10, 2010 | Televison & Video
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
How do i connect awa set top box with a dvd player and tv, setup yo tv is easy but i also want to use dvd player
Hi
Thanks for using FixYa. Please see this diagram to check the set top box, DVD player and TV connections---
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Televison & Video
TV Setup
Are you using a top of set box? If not make sure the set is set for cable then do a auto program/ channel search. The tv most likely is set for ANTENNA .. If you have a top of set box it could be the problem..
Apr 21, 2008 | Insignia 37" LCD Flat-Panel HDTV
Tatung V20CCBX-U02 Television Logo
44 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
