Question about Intel REALTEK nc-r150201 Network Adapter
CANNOT GET SOUND OR VOLUME CONTROL - Intel REALTEK nc-r150201 Network Adapter
Install the sound driver. and if problem remains go for a free diagnosis at mentioned link
http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
What are the main cause of a choppy sound when you try to adjust volume
Dust accumulation on the inside of the volume control. With the amp off rapidly change the control from stop to stop several times or until the sound is no longer choppy. If this doesn't work then the volume control will need to be replaced. This trick works for a car radio too.
Jun 20, 2015 | Audio Players & Recorders
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
What is referred by volume control?
hi when we say volume control its mean you are controlling the sound level volume of particular audio usually used a potentiometer (resistor ) to have a volume control in particular unit.hope this information help you good day.
Sep 07, 2011 | Computers & Internet
Is there a sound/volume lock key that may have been hit by mistake........audio and sound in my computer dont see any fault, but have almost no sound
I can help you with your 'almost no sound' computer problem.
The best thing to do when you are not sure what your pc is doing with its sound is to bring up your audio mixer. Do this by right clicking on the volume control icon by the clock on your task bar and selecting 'Open Volume Control', or go through the Control Panel if your taskbar has no volume icon visible.
When looking at your mixer, set Master Volume and Wave mixer bars to about 75%. Now return to whatever application you are using and check where its volume is set. Generally, everything should be set to 75% and then your external speaker volume should be set to a comfortable level.
I hope that helps.
Aug 30, 2010 | Acer NSK8458AN Keyboard
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Cannot access volume control
just try repair windows or scan ur drive in antivirus maybe virus disable that volume
Sep 02, 2008 | Toshiba Satellite L25-S119 Notebook
Volume
you might want to look into one of two options... either an external sound card, or a keyboard that has mltimedia buttons on it.
If you go with the former, the Audigy 2 NX external sound card might be want you are looking for. It's small and has volume controls right on the top. Granted, it is overkill if you just want simple volume control. However, if you don't have a high-end sound card already, it could be a nice addition to your desk..?
Jul 05, 2008 | Acer Aspire 3610 Notebook
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sound only works while testing and is usually low. DVDs or any sound from the internet do not work. This problem has been there for a long time and its really irritating me. Thank god i found this site....
I will assume you have windows xp, since you did not state with OS you are using. Is the sound turned up on the volume control? On the volume control make sure both the wave and master volume are correctly set.
If you do not know how to open the volume control, goto start, then click run, not type "sndvol32".
If this is not the case then you are having driver issues with your sound card. Make sure the sound drivers are installed and configured.
First check the volume control then check the drivers.
Feb 01, 2008 | Acer Aspire 5610-4648 Notebook
Intel REALTEK nc-r150201 Network Adapter Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
