Question about Oster 4724 Rice Cooker
Fixing electric fan - Oster 4724 Rice Cooker
Canon ir3300 error code 000805-0002
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
DC controller PCB is faulty.
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Nov 09, 2016 | Canon Ir 3300 Black & White Copier
Cooling fan resistor
try a company called e spares on the internet
Jan 21, 2014 | Stoves 900DFa Dual Fuel (Electric and Gas)...
The fan doesnt work
and nothing is there a fan motor available.
Did you mean " and nowheres is their a fan motor available"???
THat leaves you with 4 options.
1. prehaps the switch to the fan is not giving the fan any electricity when you turn the switch 'on'
2. prehaps there is a bad wiring connection to the fan and the repair is as simple as fixing the supply wiring.
You need to make sure that the fan is getting electricity before saying ,I have a bad motor. You could have a bad on/off switch or wiring to the switch or to the fan.
if you do have electricity going into the fan motor.
1. disassemble , repair, and reassemble the fan motor. That assumes that you can get repair parts and already know how to fix cieling fan motors or can even find a ceiling fan repairman.
I think cieling fan repair is a decesed industry[the job died because of lack of customers] like tv repair and microwave repaair,dead professions.
Many things from china are made as one shots[if they done work on the first shot,they never will because there are no replacement parts available in the usa. You have to fly to china to buy parts.
2. buy a new cieling fan from amazon.com
Mar 02, 2013 | Hampton Bay 24002 Ceiling Fan
Ac only gets cool when car is moving
Walk around front and make sure the electric fan kicks on when you turn on the air conditioning.
If the electric fan is not kicking on, the most common failure point is the relay. I have never worked on a fan on an e46, but a quick scan of the forums indicates that on this car, there is no relay but there is some sort of control box attached to the fan that turns on the fan based on a signal from the DME.
The complete fan with control box is very expensive, but one fellow reported fixing his electric fan problem with a new fan motor that he got on eBay.
Jun 12, 2011 | 1999 BMW 323 Series
My Marley extractor fan in the bathroom has stopped working, how to investigate the problem and find a fix
Chances are the motor has burned out. Fans are quite cheap and not worth repairing.
In the UK you can get a complete replacement fan from Screwfix for under £20.
Turn off electricity at consumer unit and remove fuse / turn circuit breaker to off.
Undo screw and remove front cover from the fan. Carefully disconnect wires, remove fixing screws.
Follow instructions included with new fan
Feb 21, 2011 | Home
NEED TO FIT REPLACEMENT ELEMENT IN LOWER OVEN TOP SCREW BLOCKED BY FAN
To remove the fan unscrew the fixing nut clockwise as though you were tightening it, as it is a left hand thread, hold the fan blades at the same time to prevent the fan turning.
Ensure power is OFF.
Hope this helps.
Dec 11, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Neff U1721 Double circotherm Electric Oven
Fixing Ceiling Fan
An easy-to-install ceiling fan can make a real difference in your home's climate - both cooling and heating - at a far lower cost and operating expense than almost any other item.
The installation begins with choosing where the fan should be located. In almost all homes, the fan is installed in the center of the room, replacing a central light fixture. This spot provides a smooth air flow to most of the room. Since a fan draws about the same power as a ceiling fixture, the electrical circuit shouldn't be overloaded. But if your fan includes lights, be sure the circuit it's on has enough extra capacity to handle the load. If not, you must run a new circuit with a new circuit breaker from the house main service panel or subpanel to the fan. If there is no central light fixture, you'll have to create a place to hang the ceiling fan. Then, you'll need to bring electrical power to it. You can tap into an existing circuit to do this.
Sep 25, 2008 | Dryers
REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Jul 09, 2008 | Neff U1721 Double circotherm Electric Oven
Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Aug 15, 2007 | Neff U1721 Double circotherm Electric Oven
Oster 4724 Rice Cooker Logo
24 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
