Question about Mipro MR823D UHF Dual Channel Diversity Wireless Microphone System Microphone
Mipro mr-823d radio mic keeps going off
Hi, i have the twin mipro mr 823d uhf radio mics, every now & then the sound goes off, battery connections are fine, so are all the connecting leads, any help greatly appreciated,
thanks, dave
I have 2 cobras 29 radio always worked good till recently. Have a rk56 mic I can hear but can't talk. Mic keys up but they hear nothing bought a new 29 chrome digital read out and a new mic just a wood...
If you are saying that you put out a signal but they can't hear your voice, the battery in your microphone is dead or the 9 volt battery clip that plugs onto the battery may be broken. Try the battery first since a new battery should make the light come on and your voice to modulate your signal so people can hear you. :-) Mr. 44
Aug 26, 2014 | Radio Communications
Wiring a mic to a ham radio.
Get the schematics, isolate the circuits, and apply the fix. But... You probably want all those details.
Dec 07, 2013 | Kenwood TM V71A VHF/UHF Mobile Dual Band...
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
I pulled u uhf out of my vehicle and replaced it with a pro 520 xl uniden uhf but it won't work.
Check your electrical connections and your antenna set up first. Then if you still have a problem, check your mic/mic plug. Lastly, check your programming. If you have ignition sense programmed into the radio you will need to wire it accordingly, so it will sense the ignition of the vehicle.
Best regards.
Sep 13, 2013 | Motorola UHF 1-Watt, 1-channel Radio
Trying to determine the cause of intermittent signal from microphone on a vx 4600 radio
Yes, short or lack of a good ground. It could also be the cord attached to the mic. The mic itself should provide the needed feedback to the radio that a mic is plugged in. Do you have anything connected to the accessory jack in the back of the radio? That can cause the same issue.
Apr 07, 2013 | Vertex Standard VX-4600-G7-45 PKG-1 UHF...
Kenwood TM-732A 440 Mhz cycles on and off when mic is keyed.
Sounds like you have an antenna problem on the UHF side.
Feb 02, 2013 | Kenwood Radio Communications
Noise comes from the cordless microphones when the battery is getting flat. Is there an indicator which can tell me when the battery is about to get flat? I am using an MR-801 a system. How do I avoid this...
Hi, the noise is the sign that the battery is gong flat, that's how the mic was done.When it goes flat,it makes some kind of disturbed sound for you to know that the battery needs to be replaced.
It's normal.
Thanks for using fixya....
Oct 26, 2010 | Mipro MR-123D Dual Diversity And Dual...
I have a midland twoway radio I dont know if its a VHF or UHF model # is 70-530B also need mic wiring thank you...
It is a 25W UHF radio 445MHz-455MHz
Type accepted for land/mobile.
Sorry, no info on the mic wiring.
Oct 04, 2009 | Midland Radio Communications
No sound from MIC but the RF light is growing
is it a power mic change battery also check white wire connection
Aug 01, 2009 | Vocopro UHF-3200 Professional Microphone
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
140 people viewed this question
Top Mipro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mipro Audio Player and Recorder Expert? Answer questions, earn points and help others
