Asko w6342 Noisy drum bearing
  • 3 Answers
SOURCE: noisy bearing on drum
This is not an easy job on any washing machine. The AEG is probably the same as most washing machines in that it has two bearings on the shaft at the rear of the drum but it also has a carbon water seal on the inside and usually you will need to change this too as if you disturb the bearings it will surely leak. If you have never done this before it can be dreadfull. If your drum has bolts and a seal at the back to withdraw the inner drum and back plate out the back of the machine then you are lucky and you should be able to do the job in about two hours. If you dont have a removeable back on the drum you will have to strip the whole machine and remove the drum supports and hydraulic pistons at the bottom. All hoses and pipes and wiring attached to devices on the drum will have to come out as well as the door seal and soap dish rubber connector. Good luck.
Posted on Apr 03, 2009
  • 351 Answers
SOURCE: replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Posted on Jun 16, 2010
  • 170 Answers
SOURCE: bearings realy noisy on drum
Bearing is part of rear tub//tub has two pieces frount and back .Need more info to tell you how that part would be sold///sometimes outter tub comes as complete unit with inner basket ..........If I helped you please vote need more help please ask....good luck
Posted on Feb 04, 2011
chans007
  • 66 Answers
SOURCE: noisy drum bearing also play
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Posted on Apr 30, 2011
  • 148 Answers
SOURCE: ASKO W6342 washing machine drum does not turn on any cycle, machine fills and empties ok and drum can be turned by hand ok, belt seems fine too
regulator knob or switch is faulty , needs replacement.
Posted on Mar 14, 2014
My ASKO W6342 washing machine drum will not turn on any setting, it fills and drains fine but the drum does not turn during the cycle, however it is free to turn by hand, the belt from the motor is OK, I...
It seems a minor problem for me, but cannot say anything without checking your washing machine. You should better call washing machine repairer to fix this minor problem.
Mar 14, 2014 | Asko Washing Machines
Reset asko w6342
you do you know that you have to wait up to 3 min for some doors to open as there is a safety lock on them other than that check your door lock
Jan 27, 2014 | Washing Machines
Replace drum bearing ... in a ASKO W6551 step by step
Jun 05, 2010 | Asko WL6511W Front Load Washer
My Asko stacking dryer makes a small squeaking noise
Hi, Check for the following:
  • Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time
  • Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
  • Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
  • Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Apr 17, 2010 | Asko T761 Electric Dryer
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
VERY noisy GE profile electric dryer
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=DPSQ495ET4WW&mfgModelNum=&fkMfgID=2 The problem you are having is with the front glides and the back bearing . # 316 on the door diagram.& # 543 on the drum diagram. those are the parts to replace.
Dec 22, 2008 | Asko T701 Electric Dryer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
