Both fan and heating coil stopped working
SOURCE: broan nutone 721
If you remove the the lens there should be a model number online. There are several places online that sells parts. The 721 is a Broan part if yours says Nutone then you will need to try to find that model number.
www.nutone.com
https://www.centralvacuumstores.com/fan_help.php
www.rinutonedistr.com
SOURCE: Older Nutone bath- fan/light/heater Model
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
SOURCE: how do you access the light on a broan
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Testimonial: "Didn't exactly correct, but I looked further and found 2 screws. "
SOURCE: i have a broan model 150 ceiling mounted heater, i
I cannot be specific about the wiring from the model information you provided. However this link to the model 154 may be useful if the two appear similar to you.
http://www.broan.com/ImageLibrary/broan/pdf/InstallGuides/99041890.pdf
In this case, yes, the neutral must connect to the element and fan motor.
SOURCE: we have a "Nutone"- ceiling
You might be able. check Ebay. but it being as old as it is, you may not be able to find parts anymore.
