Question about Proform CrossTrainer Treadmill
Proform 345 crosswalk wont incline , spindle wont catch teeth
  • 64 Answers
SOURCE: Pro Form C525. Then incline motor works with a
The repair for this is usually a new elevation motor. However if elevation isn't a big issue for for you, you can disconnect the elevation motor and use treadmill like that. The elevation motor doesn't go out that often. You should check with a local repair person. They may have a used one laying around. I usually keep one on hand to test with.
Posted on Nov 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: My proform 515s Crosswalk treadmill works for a
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt. 4. After completing the steps above go to your local hardware store and purchase a can of silicone spray ( Pyroil, Napa etc ) attach the nozzle and proceed to spray length wise starting at the motor shroud to 2/3 down the deck repeat the process on the other side then re-tension the belt according to you owner's manual. Start unit and proceed to walk on it if the unit shuts down again then belt and deck needs to be replaced or your in the market for a new treadmill.
Posted on Jun 30, 2010
ercupa190
  • 12223 Answers
SOURCE: proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: My proform crosswalk 397 is stuck on incline how
RUN THE SOFTWARE CALIBRATION INMEDIATELY FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you must lube the gear and shaft very well, 3) adjus the potentiomenter for to try to fix it.
Proceed according with the instruction manuall, if you do not have go for free download: www. fitness.manualsonline. com or www.iconservice.com
Posted on May 06, 2012
ercupa190
  • 12223 Answers
SOURCE: Proform crosswalk 397 will not incline
see the diagram, and RUN the software calibration for diagnose and troubleshooting.
lube the gear and racking from elevation motor, clean, and tigh any wires connectors:
Posted on Jun 30, 2012
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Jun 29, 2012 | Proform Crosswalk 397 Treadmill
lube the elevation motor see the diagram attached:
RUN the software calibration for diagnose, and troubleshooting.
Jun 29, 2012 | Proform Exercise & Fitness
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
My Proform 380 treadmill will not run the incline goes up and down but the motor/ belt does not move
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
May 31, 2011 | Proform Crosswalk 500 Treadmill
Proform CrossTrainer Treadmill Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
