Question about Broan-NuTone 157 Compact Heater
Thermal protector p/n 19865-000 on nutone model 9290
Is this a common problem with this type of ceiling heater?
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do you get the cover off of the nutone 9093wh
Go to link below to see how to remove. Page 2 figure 4
http://www.nutone.com/PDF/InstallGuides/9093ins.pdf
Posted on Dec 27, 2009
SOURCE: What is the thermal fuse
Our thermal fuse blew as well, and my son was able to read the small print. Mine is a MicroTemp SRCAXK G4A01 TF 100, which according to the ThermoDisc website appears to have an open temperature of 100C (212F).
Posted on Jan 03, 2011
  • 3 Answers
SOURCE: Nutone, Model QTXN 100HL-A 1500 Watt
The "diode" that your electrician mentioned is actually a one shot thermal fuse.
You can either go to the Nutone website for parts, or remove the thermal fuse, extract the info written on it and buy a replacement. Mine was a 100C 10A thermal fuse. I got mine from DigiKey.
Posted on Feb 15, 2012
How to test for a defective thermal protect on nutone model 9290 ceiling heator ??
Disconnect wires to thermal protecter and jump them together, if unit works then you have a defective thermal protecter
Apr 19, 2014 | Broan-NuTone Heating & Cooling
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link: http://www.centralvacuumstores.com/nutone/Broan-Nutone-Heater-Elements/QTXN-Series.php
Hope this helps!
Sep 06, 2010 | Broan-NuTone Heating & Cooling
Nutone, Model QTXN 100HL-A 1500 Watt Does not heat. Electrician said it was the heater part that has "6260 Eichen 04" on it. He said it was the diode. I would like to order the small part.This is a...
Mar 29, 2010 | Broan-NuTone Heating & Cooling
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Older Nutone bath- fan/light/heater Model #9111. Light works, fan and heater do not. Must I replace the entire unit.
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Aug 28, 2009 | Broan-NuTone (8663RP) Ceiling Fan
Need to change light on old nutone heater
If there are no visible screws and no knob in the middle of the grate to unscrew you have a model which simply pulls down. If it has been up there for a while it may have been painted over so you will have to use a razor blade knife to cut through the paint around the perimeter. Once that is done, use a putty knife to carefully pry the grate away from the ceiling about one inch at a time, working your way around from side to side.
May 17, 2009 | Broan-NuTone N671 Nautilus Ceiling Fan
Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Feb 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone 157 Compact Heater Logo
93 people viewed this question
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
paulcarew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
