Question about Jebo Aquarium Lighting Al-Alloy T8 Light: Fits 36" Tanks - 2 x 20 Watt
How to get the tubes out
How do I get them out to change
Inner tube sizes
most tubes don't come in specific width sizes, so the correct on may be 20x1.25-1.75 or 20x1.5-20 etc, you probably wont need to change the tube.
Nov 26, 2012 | Dahon Speed D7
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Nov 08, 2010 | Akai PT4250A 42" HDTV
Im changing out my compressor and have been advised to change out the ac capillery tube as well i just would like to know what it doesthanks for the time spent on this
The cap tube is the metering device which meters the amount of refrigerant allowed into the evaporator coil and thus, is one of the steps within the refrigeration process.
On system with a cap tube metering device, a common failure is the cap tube gets plugged, and the compressor in turn burns out. So it becomes common practice to change out the cap tube during a compressor change-out and also to add a low pressure switch to prevent the new compressor from a quick failure if there is another problem somewhere.
Don't forget to change the filter drier as well. Very important. Please leave feedback if this suits your needs for knowledge.
May 16, 2010 | Heating & Cooling
Coolant leaking from tube between cylynders
Yes you can. If you remove the clips from the tube you can move it one way and change 'o'ring. Slide it the other way and change 'o'ring. Move back to centre and refit clips.
Mar 03, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
2001 vt1100 c3 aero. coolant leak from tube between cylinders. how do i repair?
The tube should be sealed with 'o' rings. Remove clips from tube. Slide tube into one cylinder. Change 'o' ring for a new one, lubricate it, and push tube into other cylinder. Change that 'o' ring, lubricate, centralise tube between cylinders and refit clips.
Jan 14, 2010 | 2001 Honda VT 1100 C3 Shadow Aero
Need to change blue tube, just unscrew and replace with t.v. unplugged?
No - Your TV has tubes not lamps.
Why do you beleive you need to replace the tube. 99% of the time the problem with this model is just the fluid.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Can't change plug on plug next to firewall, under dipstick resivour.
yes take the 10mm bolt from the tube and wiggle the tube up out of the way
Apr 16, 2009 | 2001 Dodge Durango
T-49F
To change out your cap tube you will have to do the following.
Purchase cap tube replacement from supplier.
Recover your refrigerant.
Use your torch to remove the cap tube.
Weld in new cap tube (make sure you have it cut to the proper
length)
Pull a vacuum on the system.
Charge unit with recovered refrigerant.
Feb 03, 2009 | True T-49 Side by Side Refrigerator...
Replace Ice maker tubing LG Armoire refrig
Normally I would change the entire tube, but if you like you can take a sample of the tube to a full service hardware store (not a big box where they don't know anything) and get some tubing and / or some insta-push fittings. They are fast and work great.
Dec 11, 2008 | LG LFX25960ST Stainless Steel French Door...
Fuzzy blue
are u a tech? if you going to replace the tube i dont feel there much difference. both involve remove tube and puting back in and adjusting...just that glycol change is cheaper than the whole tube replacement. a little more work. have u evere changed a tube
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Jebo Aquarium Lighting Al-Alloy T8 Light: Fits 36" Tanks - 2 x 20 Watt Logo
383 people viewed this question
Top Jebo Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Jebo Fish Expert? Answer questions, earn points and help others
