Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
Flashing antenna signal - Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
I have an akai 42 in tv and the scren is flashing searching no channels just a blue screen saying searching then it says power off in 15 min i dont have an remote control
Is it connected to an antenna or cable source? If not that would be the first step. If you have no signal it can cause the screen to flash . A factory remote would help greatly but you should be able to do something by pressing the buttons on the tv.
Aug 07, 2014 | Televison & Video
Troubleshooting
check the batts, all batt contacts and wires. then carefully remove cover , and check the antenna leads. look for broken solder joints. most all electronic repair shops will have a signal generator , as well as a reciever to check if you have the right signal ..out.. or if it simply needs adjusting. hope this helps ... dollar store sells soldering irons
Jan 03, 2014 | Computers & Internet
My 50 inch Philips Plasma TV is normally connected to a Virgin Media HD Box in order to watch TV programmes. Tonight my TV is showing a box that is called Information, and it has the wording No signal or...
Unplug both the set and box from power for a while--either may have caused a glitch---power both back with everything already connected and see if the reboot that will happen helps or not--a lot of times the box causes this by confusing the set it is connected to.
Nov 06, 2012 | Philips Televison & Video
Samsung HL-5667W The picture has 5 vertical lines in it that are pink & green with ant input.Also the rest of the pic is grainy & flashing. The internally generated pic is perfect.What is possible...
RF signal you are receiving needs to checked and repaired if you are a using settop box as your RF receiver and it has AV options use them and check how the signal is if directly,if from antenna check cabling if not broken or corroded and check antenna receiver box for corrosion
Oct 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
No signal
Lets start from the top, first off do you have a cable box, antenna, or dish type service?
Mar 07, 2008 | SVA-USA HD4208TIII-VR 42 in. Plasma...
"No Signal" Keeps Flashing on the Screen
I would suspect you have a weak or intermittent source. If it is cable, you may want to have them check it for you. If you are using an antenna, you will want to get a better one or at least try a different position.
Dec 20, 2007 | RCA 14F512T 14" TV
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
20 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
