Question about keyscaper England Wireless Usb Mouse
Wireless keyboard drivers - keyscaper England Wireless Usb Mouse
Why can't I use my wireless keyboard
Did you download the wireless keyboard drivers from the internet, or
did your laptop automatically download the drivers for your keyboard once you turned on your laptop? Is the keyboard Dongle that came with you wireless keyboard plugged into your USB port?
Aug 24, 2014 | HP Pavilion Computers & Internet
My mouse work but not my wireless keyboard
Hi, 3 items top choose from ...
1) There is a sync button at the base of the wireless keyboard and the wireless receiver. Press the button on the wireless receiver and then on the wireless keyboard. They should now sync. and your keyboard should then function.
2) Most likely that the drivers for the keyboard may have been updated when your pc does windows update. You may need to re-install the drivers for the wireless keyboard
3) reboot computer.
Good luck .. hope this helps.......
Oct 07, 2010 | Computers & Internet
How do i turn on my wireless keyboard
1 Follow the steps mentiond below:
•2
Leave your current wired keyboard plugged into the computer. Many computers will cease to function if their keyboard is removed.
•3
Make sure that the computer is on and is functioning properly.
•4
Plug the USB wireless adapter of the wireless keyboard into a USB port on your computer. If you don't have a USB port, then your computer is probably too old and likely won't support a wireless keyboard.
•5
Make sure that there are batteries in your wireless keyboard. Oftentimes, the consumer is responsible for putting the batteries in, and they don't come with the keyboard when it's purchased.
•6
Turn the power on for your wireless keyboard. The method of doing this varies depending on the model you've purchased, but the power switch/button is generally located on the bottom of the wireless keyboard.
•7
Wait for the keyboard to download it's driver software. If you don't have a connection to the Internet, use the software that was included with your wireless keyboard to install the driver manually.
•8
Use the wireless keyboard exactly as you would a wired keyboard.
Aug 31, 2010 | Computers & Internet
Problems with wireless keyboard and Office 2010
It looks like office has replaced or corrupted your keyboard driver. You'll need to reinstall it, Windows may try to tell you it already has the best driver, hit back then tell it the location of your replacement driver and have it reinstall that one.
Jul 02, 2010 | Microsoft Standard Wireless Optical...
Hey i lost my cdinstalation for my keyboard and mouse how can i make it work ?
try to reinstall the Wireless Keyboard and Mouse driver software. you can download the Wireless Keyboard and Mouse driver software from your Wireless Keyboard and Mouse manufacturer's web site then restart the computer .
Jun 10, 2010 | Laser Gigaware Wireless Keyboard/Mouse
My computer stopped recognizing my wireless keyboard & mouse. Says it's missing a driver or that the device is malfunctioning. Don't think it's a battery prob. Do I need a new driver?...
Uninstall the Keyboard driver.
Unplug the Logitech keyboard.
Restart the computer.
Plug the Logitech keyboard back into the computer.
Windows should recognise the keyboard and/or the mouse.
Place Logitech setup disk in drive.
Reload the drivers...
The drivers sometimes corrupt themselves..
You might download the latest drivers for your keyboard/mouse.
Jun 28, 2009 | Logitech Wireless Access Duo Optical...
Logitech wireless keyboard
  1. Here's a few generic troubleshooting steps for a wireless keyboard you can go through.
  2. I assume its RF wireless since you did not mention Bluetooth. It operates at 27Mhz which makes it susceptible to interference from common consumer electronics, so make sure area is clean of any electronic devices.
  3. Some wireless keyboard models provide a channel selection switch to switch to other channels to escape interference
  4. Having the wrong driver or missing Driver will cause it to not work. Go to device manager, find your keyboard device, right-click on it and update driver. Also you can uninstall the driver, then reboot and plug and play should pick it up and load driver. Or re-install original driver if it was on a disc. Driver is important so do all you can with the options you see. Well that's it, good luck, and let me know how it turned out.
Jan 03, 2009 | Logitech Wireless Access Duo Optical...
My wireless keyboard stopped working it is a A4tech RFKB-21
The first thing you should try is unplugging the wireless adapter and plugging it back in. If that doesn't work, try uninstalling the wireless driver (from the device manager. You can find the device manager in the control panel), unplugging the keyboard first of course. After the driver has been installed, plug the keyboard back in and allow the windows 'found new hardware' to install the driver again. The 'found new hardware' dialog is automatic, so all you have to do is plug the keyboard in.
If windows cant find the driver, or has a problem for any reason, you can find your driver at:
http://www.findmysoft.com/drivers/A4tech-RFKB-5-Wireless-Keyboard-driver.html
and install it manually (it installs like any other software).
If your keyboard is still not working, check for any manual locks that might prevent the keyboard from being used normally. Look for an unrecognized key, a switch, or an LED light that might have a picture of a lock. Unfortunately, I can't pull up any pictures of your keyboard, so I don't know if it has one or not.
You might also want to try another usb device (a flash drive or another usb keyboard, if you have one) to make sure that the usb ports aren't the culprits.
I hope this helps, and good luck!
Jul 16, 2008 | Compaq Keyboard
keyscaper England Wireless Usb Mouse Logo
Top keyscaper Computers & Internet Experts
David Payne
David Payne
Are you a keyscaper Computer and Internet Expert? Answer questions, earn points and help others
