Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Key not in use
We are getting a "Key Not In Use" error when trying to put our pool pump in manual or egg timer mode.
  • 3 Answers
Yellow is the color to let you know that there is power to the pump, witch allows the pump to run according to your predefined start up settings. If you turn the power to the Pump off, the yellow light goes out, and after 72 hours, you will lose your pre determined startup settings.
Posted on Jun 17, 2014
Intermittent Intermatic Pool Timer T40003RT3 The pool timer is 220v but only one 110v 20amp breaker in the breaker box to the pool equipment and when it is off the pump will not run in manual mode.
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#RT3
RT3 series has T104 240 volt timer -or- T103 120 volt timer, -plus- low voltage transformer for pool light.
The circuit breaker can be used for transformer, or another outlet or nearby light etc, or it can be used for a T103 120 volt timer.
To trace the wire back to breaker box.... open you main panel and start turning off breakers one at a time and label the panel.
See if you have single breaker or double breaker supplying power to pool equipment.
Gene
Water Heater Timers Save Money
Jun 10, 2015 | Intermatic Timer T40004RT3 300 Watt Pool...
Error on pump says emergency shut-off engaged, what can I do
the suction has been altered and set the emergency shut off you have to clear the error and it will start up or put it on manual mode
Sep 30, 2014 | Pool & Spa
How do I clear a "Key Error" when trying to get to "Schedule" mode to set Start and Stop times?
your hitting the wrong key see youtube for how to program your pump i used it and it was helpful
Aug 16, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pool time switches pool on, but off does not trip off, and can't do it manual. When I push it on off, the pool pump tries to stop but continutes running. Have to use breaker box.
Model number of timer is not known.
Is this new installation? Or installation that worked before and recently stopped working?
If the manual override lever on timer does not turn Load on-off, then 1) wiring is wrong or 2) timer has gone bad or 3) pump has a short.
I suspect a short since you say the pump 'tries to stop running.'
Copy following links for troubleshoot walk-thru, and correct wiring:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
How to program intermatic pe 153p
PE153 comes with P1353 timer.
The timer instruction manual is too long to copy.
Read manual, and add a comment with specific question about any part of manual.
Add as many comments as needed.
http://waterheatertimer.org/pdf/P1353ME-instructions.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
P1353 is 3-channel timer.
3-channels means that timer can control 3 separate circuits, each with different timing schedule.
Timer has 5 different modes.
Page 13 of manual shows modes.
Select different modes depending on what type of device(s) you are controlling with timer.
For example, 2-speed pool pump, you select MODE 2 or MODE 4
http://waterheatertimer.org/images/P1353ME-2-speed-motor-500.jpg
By selecting Mode 2 or 4, the timer protects against programming conflicts that would turn on both speeds at same time, and cause electrical problem.
Aug 15, 2011 | Intermatic Digital 3-Circuit Timer...
My timer for my water feature looks like your Intermatic T101R3 timer. I do not have an instruction manual. Can you e-mail me some simple instructions for using this so I won't get charged an...
T101R3 is outdoor pool timer with fireman's switch.
Some are double-pole, some are single pole, some are 240V and others are 120V.
They each look like the other so eyeball identification is not enough information.
The model number should be inside door of timer.
http://www.poolandspacontrols.com/products/mechanical%20time%20switches/pool%20and%20spa%20time%20switches.aspx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
I have been unable to locate manual specific for these products, and I have looked.
I was looking yesterday for this instruction manual.
Some wiring diagrams appear on following page, but again it depends on your specific model
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The T101R series is designed to control pool pump and pool heater.
Fireman's switch automatically turns off pool heater 20 minutes before pool pump is scheduled to turn off.
So you set the trippers on dial, and then the fireman's switch does the rest automatically.
Add a comment with in-focus photo of inside of timer door and I can put together all the information and simplify instructions. Put your digital camera in 'macro' with the flower-symbol to take close-up photos. Photo has to be in focus so I can read information and see wiring schematic.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 20, 2011 | Hardware & Accessories
Installing a outdoor timer t104m this is for the pool cleaner,need wireing instruction.next to pool pump timer.
Open following link for wiring diagrams and manual.
240Volt T104 can be wired many different ways.
What is the significance of 'next to the pool pump timer?'
Are you getting power off the 240V pool pump timer to operate the new T104? This is perfectly fine. The pool pump wires would bring power from the breaker box.
Is the new T104 going to control 120Volt lights? The timer can do that, it just has to be wired correctly.
In any case, the T104 has 240Volt (or 277V) clock motor, and clock will not operate with 120V
If you add specific details, I can help with exact wiring diagram for your project.
Apr 18, 2011 | Intermatic Hardware & Accessories
Install a timer to control pool operation
Another option would be to get an electronic timer like the Intermatic P1353 that has 3 circuits on it that you could program to cut on and off at different times. For example, you could have one circuit that controls the pump and turns the pump on, then the second circuit would turn on the booster pump at a set time after the filter pump had come on and then the heater could be set to also run at a preset time after the pump circuit was activated. Since the pump, booster and heater are all 220, it's a straight forward hookup with everything in one timer box.
The lights, as stated before, would be on a separate circuit (110) and have its own timer or photosensitive eye set in line.
May 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
May 13, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
389 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
