Question about Garden
I tuned up my toro z5035 plugs filter &oil change. after starting the mower iit was running very rough & blowing black smoke from the exhaust . i pulled the plugs 1 of them was covered in a bl
I tried relacing the 1 plug that was covered in the black soot & it fouled out just as quickly. when i adjust it to high idle it does not rev up very high & black smoke billows from the muffler
  • 11 Answers
SOURCE: 4.5hp Brigss & Stratton engine.Engine runs rough.
Ok, check the air filter, it could be clogged. A clogged air filter won't allow a proper air-gas mixture. Then check the carb. make sure that it is clean, or if anything doesn't look right. You might have to get another carb. After that check the intake it could be clogged but this time a clogged intake means that there isn't enough fuel getting to the combustion chamer.
Posted on Aug 12, 2009
woobie dog
  • 1273 Answers
SOURCE: my lawnmower starts fine but runs rough,it does
Hello.
Replace the air filter. This could be the source of your problem.
Best regards, --W/D--
Posted on Apr 29, 2011
motor1258
  • 6674 Answers
SOURCE: Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Posted on Dec 05, 2011
  • 6468 Answers
SOURCE: I have a 10 year old Craftsan yard tractor with a 17hp OHV Kohler motor. Went to start it up and it started up fine, belched white smoke and stopped running. Looks like there is oil leaking into the
check the oil see if it smells like gas sounds like the needle valve in the carb is not seating and the carb over flows into the crankcase
Posted on Aug 26, 2012
  • 2239 Answers
SOURCE: a 450 series 148cc on a victor, mower starts but runs rough(low engine rev and blows black smoke)
There has been a great deal of issues with the diapham between the carb and the tank, replace it and hopfully all will be well again.
Posted on Mar 10, 2013
Powermore 173cc OHV - suddenly running rough burning twice as much fuel as before. Blowing black smoke out of the exhaust. Is there a float that might be stuck open?
It.sounds like you have a hole in the float. If the float was.stuck, the oil would be filled with gasoline. With a hole in the float, the engine would flood, blow black smoke and run rough. Remember, black smoke is fuel, white smoke is water, and blue smoke is oil. Hope I helped.
Sep 04, 2013 | Garden
Craftsman 550 series 5.5 torque 158cc motor runs roughly. I can clean the plug and it will run clean for about a minute, but the it starts running roughly again. I have changed the plug, the filter...
Todd are you using fresh fuel and is it unleaded. The plug sounds as if it is coking due to burning something other than fuel. Also check the oil level.
Aug 18, 2013 | Garden
A 450 series 148cc on a victor, mower starts but runs rough(low engine rev and blows black smoke)
Mar 10, 2013 | Briggs & Stratton Garden
John deere 445 96 w 22 horse kawasaki fuel injected starts fine runs but rough with raw exhaust gas new olugs new fuel &filter new oil
When it runs rough is it blowing dark smoke? This is a sign of running rich like a choke will do and can cause stalling especially when the motor is warmed up. If it is not blowing dark smoke it sounds like maybe your injectors are not working properly and it is not getting enough fuel through them under load. either way as an injected machine it sounds like injectors may be the culprit since youve taken care of some other issues. You might try running a heavy dose of an injector cleaner through it (I've had good results with lucas brand) and see if that helps. Otherwise, you might try to manually clean the injectors.
Sep 25, 2012 | Garden
Trouble starting and a lot of black smoke at startup
Could be. Black smoke means too muck fuel or not burning properly. Also make sure your oil is not over full.
Apr 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
The motor smokes and oil blows into the carberator
if you changed the oil recently you need to use SAE30 and not 10w30. Causes pressure buildup.
Mar 03, 2010 | Toro Lawn Mower With Toro Power Tools
Tractor running rough and black puffs of smoke come out exhaust pipe when you rev up engine. What should I try?
Normally black smoke indicates too much gas or too much choke. Remove and clean or replace the spark plug because it is probably fouled. Change the air filter because it is probably clogged. I am not sure how mechanically inclined you are, so if you are then it needs a tune-up. If you are not then I would take it in for a tune-up(needle valve replacement or cleaning and adjustments, float bowl cleaning, and spark plug replacement.
Aug 21, 2009 | Garden
Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Jul 04, 2009 | Toro Lawn Mower With Toro Power Tools
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
