Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
No applications are registered for this event. Take no action: When I push the scan button on the printer to start scan to file
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: MFC 8860DN No applications
Try this:
1. Locate the Brother Control Center application. It will be running in the system tray (usually near the system clock). Right click on the Control Center and left click on CLOSE. NOTE: The update cannot be performed if the Brother Control Center is left running.
2. Click START -> RUN or in the START SEARCH LINE:
3. Type in X:\PROGRAM FILES\BROTHER\CONTROLCENTER3\SKIN\ (Note: Replace X: with the letter of your local disk drive.)
4. Right click on the MODERNSTYLE folder
5. Select CUT
6. Click START -> RUN or in the START SEARCH LINE:
7. Type in C:\PROGRAM FILES\BROTHER\CONTROLCENTER3\
8. Click EDIT -> PASTE
9. Restart the PC
10. The Control Center will open and you should see the icon appear nearyour system clock if the control center does not start automatically: Open the Brother Control Center 3 by clicking START -> (ALL) PROGRAMS ->BROTHER -> (MODEL NUMBER) -> CONTROLCENTER 3. Your issue should be resolved.
Posted on Nov 02, 2010
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    I HAVE CANON LIDE 30 IT DOESNOT WORK IT GIVES ME A MESSAGE THAT THEIR IS NO APPLICATION REGISTERed for this event
    The driver is trying to open your chosen 'image edit' (application) software (MS Paint, PhotoShop, Panintshop Pro or whatever), BUT you have uninstalled it, moved it or not chosen one ....
    Go into the Control Panel, Scanners & Cameras, choose the LIDE scan driver right click for 'properties', Events tab, Select an Event pull down = 'scan start button' (or whatever) and select (browse to) your image edit package ..
    Jun 11, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
    The scanner is not scanning as fast as it says its suppose and we just got it why is this
    Hello
    Make sure EPSON Smart Panel is installed.
    If you are using Windows XP:
    Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    For Windows Me, 98, and 2000 users:
    Click the Events tab in your scanner's Properties dialog box and make sure the Disable device events check box is clear. Also, make sure the desired button is selected in the Scanner events list box, and the desired application in the Send to this application list is selected.
    For Mac OS X users:
    When in Classic mode, the buttons are disabled. Quit Classic mode. Initially, only the user who installed the scanner software can scan using the buttons. Other users must start EPSON Scanner Monitor in the Applications folder before using the buttons for the first time. From then on, pressing a button will automatically start the application assigned to it.
    Jun 10, 2011 | Epson GT-2500 Flatbed Scanner
    MFC 8860DN No applications are registered for this event. Take no action: When I push the scan button on the printer to start scan to file
    Try this:
    5. Select CUT
    9. Restart the PC
    Nov 02, 2010 | Brother MFC-8860DN Printer
    When I push the scan or file button I get a pop up that says "There is no application registered for this event". How do I get it to scan? I have a CanoScan9900f
    Hi tobrien55
    You don't have the software necessary for the scanning and probably the driver as well.
    Click on the link below.
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8743
    • Download the Driver
    • Download the Software (Toolbox) . Make sure you select the correct Op system for the tool box
    • Install the driver and the software
    • Try a scan
    i am quite sure, you will be successful this time.
    If this answer is helpful, please give a rating.
    Have a good day
    luciana44
    Nov 14, 2009 | Canon CanoScan 9900F Flatbed Scanner
    Scanner problem
    Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
    http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=76&SRCCODE=WEBGOOCOMP&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
    If the HP director software is installed (Which it should be).
    You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
    Mike
    Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    When i scan the images are black and white not color
    Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
      Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
    2. Wait approximately ten seconds and then press the <ON/OFF> button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
    Selecting a Response to Commands from the Operation Panel
    You can specify a response resulting from pressing the <Color Start> or <Black Start> button on the machine. Setting the response with MP Navigator allows you to scan documents easily.
    Important:
    With network connection, only MP Navigator can be launched. Configure the settings accordingly.
    With USB connection, with Windows XP, the program selection dialog box will be displayed the first time you press the <Color Start> or <Black Start> button on the machine, as shown below. Select 'MP Navigator', select the 'Always use this program for this action' checkbox, and then click 'OK'. By specifying this setting, selecting any scan mode launches MP Navigator, and the selected action will be performed.
    1. Click the Windows 'Start' button, then click 'Control Panel' (Non-Windows XP: click the 'Start' button, then click 'Settings' -> 'Control Panel').
    2. In the resulting window, click 'Printers and Other Hardware', then click (or double-click) 'Scanners and Cameras'.
    3. Right-click the scanner icon for the machine, then click 'Properties'.
    4. On the 'Events' tab, in 'Actions', specify the setting to launch MP Navigator. Specify 'MP Navigator Ver2.1' for 'Select an event' and for all events. (Windows 98/Windows 2000: Select an event in 'Scanner events' and specify 'MP Navigator Ver2.1' for 'Send to this application'.) If the settings are already configured to launch MP Navigator, click 'Cancel' to exit.
    Important:
    If MP Navigator is not set as the program to launch, you will need to select an application to launch each time you press the <Color Start>/<Black Start> button.
    5. Click 'OK'. Windows 2000 only: Restart your computer.
    Setting actions for the <Color Start> and <Black Start> buttons with MP Navigator
    MP Navigator enables you to specify the response resulting from pressing the <Color Start> or <Black Start> button on the machine. You can specify the response individually for each event.
    1. On the Windows desktop, double-click 'MP Navigator 2.1'. Alternatively, click '(All) Programs' from the <Start> button on the Windows taskbar, point to 'Canon Utilities', then 'MP Navigator 2.1'. Then click 'MP Navigator 2.1'.
    MP Navigator opens
    2. Click 'Preferences', and specify settings in the Color Button and Black Button tabs to determine the response resulting from pressing the <Color Start> or <Black Start> button on the machine.
    3. Select 'Event', and configure the settings in 'Actions'.
    4. Click 'OK'. The operation will be performed according to the scan mode settings when you press the <Color Start> or <Black Start> button on the machine
    Color Button/Black Button Tabs
    The Color Button and Black Button tabs allow you to configure the following settings. Click 'Color Button' or 'Black Button' to open the corresponding tab. Setting items are identical in both tabs.
    The following scan modes are available from the operation panel on the machine:
    Save to PC Save the captured image data on your computer. Save as PDF file Save the captured image data as PDF files on your computer. Attach to E-mail Attach the captured image data to e-mail. Open with application Open the captured image data with the selected application
    Action:
    The setting items vary by event.
    I hope it helps!!!
    Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Pixma mp520 scanner won't scan
    I emailed Canon Tech Support (after searching their MP FAQ) and received this response. It worked for me:
    Please follow these steps to set the push button event for the MP520
    scanner:
    1. Click on the Windows button and then Control Panel.
    2. Double-click 'Scanners and Cameras'. For Vista users, if 'Scanners and Cameras' is not listed, click 'Switch to Classic View' on the left and then try again.
    3. Double-click on the MP520.
    4. Next, click on the Events tab.
    5. For the 'Send to this application' option, select ScanGear driver, MP Navigator, or imaging application you would like to use for the scan button event in the list.
    6. Click Apply or OK to save your settings.
    Jul 16, 2008 | HP PSC 2110 All-In-One InkJet Printer
    Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
    27 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
