Question about Crafts & Hobbies
Where can I find a battery charger for a cold heat glue gun
I need a new battery charger
  • 2712 Answers
SOURCE: Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: Glue Gun Troubleshooting
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
SOURCE: Glue gun support
Try using denatured alcohol from your local hdwe store along with a rag, comb, and even a toothpick . A test area would be my first idea; color fastness and while there is not much odor it may affect some people with allergies and respiratory problems. It will take some time but be careful not to saturate the carpet itself just the immediate area; the alcohol may breakdown adhesives bonding the carpet fibers to the backing or seaming tape on the underside.
Posted on Jan 09, 2009
sonicboomele
  • 1557 Answers
SOURCE: I have a glue gun
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Posted on Dec 07, 2010
  • 16 Answers
SOURCE: Cold heat glue gun directions??
Hi There,
Just flip the switch either forward for a brighter light or towards the back for a dimmer light wait 2 mintes and you're ready to go Unless of course its like mine & just want to be a dim flashlight not a glue gun.
Posted on Jan 03, 2011
I have a glue gun were I stuck a pencile in the hole in the back and now I cant get it out ????what to do ???
Turn on the gun so the glue heats up and then try to pull it out.If thatb doesn't worlk, you need to get a new glue gun.
May 10, 2015 | Crafts & Hobbies
Idea as to cost of this and how it works please
The cost of a glue gun varies between $5-$20 for a good one.
The glue gun works based on heat, in the front of the glue gun there is a heating element, once you install the glue cartridge and press the trigger the glue cartridge is pressed thru the heated element who melts the glue forcing it thru the front nozzle
Mar 18, 2015 | Crafts & Hobbies
Hi, can't get Stanley dual melt glue gun to
some users have complained that the trigger fails. when this happens, the glue will not heat up. if it seems to be a problem with the trigger and the gun is relatively new, i would try to return it and get a new one or get your money back
Nov 13, 2012 | Crafts & Hobbies
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Mar 22, 2011 | Crafts & Hobbies
Gun will not heat but the battery seems to be working because the light on the glue gun is on
something is probably wrong with the heating element. you can try to fix it yourself by unscrewing the plastic casing, or take it to a repair shop, or buy a new gun
Mar 06, 2011 | Crafts & Hobbies
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue doesn't advance
with some glue guns the sitting with a stick in them wile hot the stick will get hot enough to where the gripper that advances the glue slips try to bush it through some to where you can add a new stick in or when sitting for longer periods unplug to allow to cool then re heat when needed.
hope this helps
May 10, 2010 | Crafts & Hobbies
I can' get the glue stick out of the glue gun
No need for concern. Just leave it there and then the next time you use it push a new one in as needed.
I haven't met a glue gun yet where you can take out the last remnants of glue stick.
If you prefer to remove it try this:
take a paper clip and straighten it (any thin,metal object will work) Heat the glue gun,unplug it,and then heat the end of the paper clip with a lighter/candle.
Insert it into the end that you load from,sticking it into the glue stick. Wait a short time and then pull the paper clip out. The glue stick should come out with it.
I find it easier to leave the glue stick in as I said,but it's your choice.
Oct 03, 2009 | Crafts & Hobbies
Crafts & Hobbies Logo
70 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
