Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
TV powered off and will not power back up
Aprox. Three-years old, No preventive maintenance or repairs performed; bulbs, power supply,etc. No TV Repair knowledge or experience so going out on a limb.
1, Bulb, initiates power off , self defense mechanism?
2, Power Supply; just because it happens?
  • Sony Master
  • 8,617 Answers
I will need the model number of your Sony in order to help. Also does the led blink when you press power? If so let me know the number of blinks. Please respond to this same post
Posted on Jun 19, 2009
My tv is on but the standby button keeps flashing and I cannot do anything with the remote either I've unplugged it and left if for 30 mins
What make and model of TV is this? If its a LCD tv thats more then a few years old chances are its the very common problem of failing capacitors in the power supply. That will usually cause the issue your describing. I have rebuilt dozens of tv power supplies now, the term commonly referred to now is re-capping the power supply. The capacitors become leaky and the voltages go out of tolerance and the tv will no longer turn on. If you can find someone to take it apart and check the power supply board inside that would be your best bet, otherwise its time for a new tv otherwise. There is no simple fix other then repair unfortunately.
May 04, 2017 | Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
My 32 in samsung tv is about 3 years old and has started turning off while i am watching a program then wil come on by itself after 5 or so minutes
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
May 11, 2011 | Samsung LN32A330 32 in. LCD TV
The standby indicator on my TV flashes red several times after every three seconds.
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
Mar 10, 2011 | Televison & Video
I have purchsed (Sony Bravia LCD KLV-32 bx300). when i plug it in The standby indicator then flashes (red) five(5) times then there is a two - three seconds break followed by another five flashes then a...
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also, look for popped capacitors that would make the values lower than need be for the tv to power on properly.
After you repair the power supply's capacitors you may need to replace other components if needed
BUT always start at the root of the problem (power supply) and work your way to other components
Please rate if this helps :)
Mar 08, 2011 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
TV is 4 years old. Not used very much. Watching TV yesterday, everything normal, great picture, etc.. TV goes off. Checked outlets,cable, etc.. Could not get TV power back on. Any suggestions ? No life,...
Question heading shows it is Sharp LC-37G4U tv and if power indicator dose not lit if tv plugged in that means power supply board got defective and need to be replaced.
Required power supply board is available with ShopJimmy.com for $79
Click above link to view power supply board image and price info.
If you are handy with electronics stuff repair then can replace power supply board by yourself OR call local tv repair shop to do this job.
Hope these info will help you.
Let me know if you have additional question.
Thanks
Nov 15, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
While in operation the TV just shut off and can not turn it back on, not even manually. Could it need a bulb replacement? TV is only 3 yrs old. We know that it has nothing to do with the cable. If it is in...
There is no bulb in plasma tv's. LCD's have a backlight and projection tv's have bulbs.
Unfortunetly it sounds like your power supply has failed on you. It is repairable. At 3 years old I wouldn;t think you have any warrenty left (perhaps extended store type) so you want to get a repair estimate before spending any money. You may find it cheaper to get a new tv. Or not that much more. You should be able to get a estimate from Sanyo repair depots or tv repair shops or ask the local stores about repairs and they may tell you who to talk to. The repair cost can be reasonable but can get expensive if they find a lot of repairs are needed. The parts are cheap but the labor isn't (and shipping etc) so make sure you weigh out repair verse replacement to avoid a bit of a shock.
Apr 23, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Blinking power button
Blinking power light is usually due to bad capacitors on the power supply. See the tip for RCA atc336 under my profile that can apply to your set as well.
Mar 23, 2008 | RCA D44LPW134 44" HDTV
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
