Question about Coleman Heating & Cooling
My compreser wont turn on unless i put heat to my thermastat up in the roof
I just installed it all works good if I keep heat on the thermo up in the unit could it be bad 15000 btu coleman mack mod,48204c966
    Genius:
  • Coleman Master
  • 1,363 Answers
Thermostat bad.
Posted on Aug 20, 2015
motor1258
  • 6674 Answers
SOURCE: duo-them 15000 BTU roof air
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
Posted on Aug 23, 2008
  • 659 Answers
SOURCE: Themostat problem no power
Your R terminal in your air-handler is the 24v power that goes to the tstat. Look at the air-handler and match the color wire. ALL tstats have a power wire going to them. If you aren't getting power, you probably have a break somewhere in the wiring close to the thermostat you are replacing.
Posted on Apr 07, 2009
  • 587 Answers
SOURCE: I would like to run
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO
www.rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on May 12, 2009
motor1258
  • 6674 Answers
SOURCE: Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Posted on Jul 20, 2009
  • 587 Answers
SOURCE: We have a Coleman roof unit a/c on our RV. We are
GO TO rvcomfort.com
Posted on Jun 09, 2010
Which hose goes where on my 2000 pontiac sunfire heater core...
are you installing the correct thermostat the right in the head or block
3 thermostats indicate incorrect fitment method
heater hoses run either way as the water is pushed through the heater core by the pump
Apr 21, 2017 | Cars & Trucks
The car keeps over heating.
first thing to check is your anti-freeze level ...if that is good put a thermo-gun to your thermastat housing and see if the themastat is opening at the proper temp ...may just be stuck closed cheap fix
May 17, 2011 | 1994 Lexus LS 400
Have replaced my thermastat in 99 cav. 2 cyl. 3 x's, thermostat's are good they opened in boiling hot water, but when I put them in car they dont open up and car overheats very quickly, I have been driving...
Make sure that the gasket is put in right. If put in wrong, it can keep the thermostat from opening. Also make sure that you put the thermostat in the right. The sensor coil or slug goes toward the engine. The thermostat should be stamped showing the proper direction. I would go ahead and buy a new one just to be sure. They are cheap.
Nov 19, 2010 | 1999 Chevrolet Cavalier
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
My heater is not working. I put in antifreeze,
No ,it is not the thermos.It is because the rad hoses are below the top of the rad.It will take time to run and refill.Good lick MOE
Jan 07, 2010 | 1997 Pontiac Trans Sport
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
Van is overheating and stays hot
first of all make sure that there is no air pockets left in the motor. these will cause an overheat right away.
the way to cure these is run engine with and radaitor funnel and once thermo opens, run the heater on high, this should take about 10 to 15 minutes.
WORST CASE SCENERIO:
You have a bad water pump!
Feb 17, 2009 | 2000 Plymouth Grand Voyager
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
Garland oven
Replace the safety valve
Jun 03, 2008 | Garland H284-24G Kitchen Range
Heating & Cooling Logo
75 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
