Question about Sunbeam Kitchen Appliances - Others
Sunbeam presure cooker
All lights flashing E4 message when I turn on unit
SOURCE: e4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Posted on Jun 09, 2009
SOURCE: e4 code on model epc460 pressure cooker
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
Thank you
Posted on Oct 27, 2010
ZJLimited
  • 17970 Answers
SOURCE: cook's essential pressure cooker has
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Posted on Apr 23, 2011
danwat1234
  • 18 Answers
SOURCE: My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Posted on Sep 19, 2012
  • 475 Answers
SOURCE: Manual for Sunbeam Vegas Electric Pressure Cooker VEP 600
call or e-mail the manufactor or write them they might have it.
Posted on Mar 11, 2013
My Deni electric pressure cooker is showing E4? Cannot cook?
An E4 Error for your Deni means that there is a signal switch error. Turn off the pressure cooker, un-plug, and wait for it to cool. Then, try again. If it continues to give you the E4 error I would recommend contacting the manufacturer - but, unfortunately, Deni has gone out of out business.
Here is the manual for your pressure coker, if you don't already have it:
http://www.hippressurecooking.com/category/manuals/deni/
Mar 18, 2016 | Kitchen Appliances - Others
I just received my pressure cooker and it keeps giving me an error message E4. why?
Generally, the E4 error code means that the sensor in the pc is faulty and needs to be replaced. Contact the place where you bought it immediately (if it's still under warranty) or contact the manufacturer to ask for a replacement.
Good Luck!
Nov 01, 2014 | Home
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Error code keeps flashing wont pressure up and they wont stand behind their product
The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Presure weight plastic is off
You can remove the plastic cover from the vent valve and it will work fine. If you remove the plastic cap, you will need to manually tilt the valve with a utensil to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Feb 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
E4 error....What is this?
before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error.
you also want to make sure, when you use the cooker you have at least 1 cup of liquid in the cooker .. the measure cup that comes with cooker
Oct 25, 2008 | Wolfgang Puck 5-Quart Electronic Pressure...
Kitchen Appliances - Others Logo
27 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
