Question about Pioneer AVIC-D3 Car DVD Player
How to connect steeringwheel contros to a pldnv78i
Not able to active after reset pldnv78i
Not sure what connection method you have.. do you have USB driving the touch screen or all inclusive HDMI, or serial port... Anyhow, you need to check your drivers and remove and reinstall them. It is most likely a driver problem. Next check cabling if the touch screen is outside the video signal (non-HDMI modality).
Jan 29, 2014 | Pyle Pldnv78i 7-inch Double Din...
I want the installation manual for this product
Manual for what? Plug in the power, plug in the display port and your done. What are you trying to do?
Nov 30, 2012 | Pyle Pldnv78i 7-inch Double Din...
1994 grand cherokee laradeo shimmy's and steeringwheel vibrates violently between 40-50 mph
1= Universal joints or yokes, or drivesshaft splines are worn.
2) driveshaft is bent
3)engine or transmission, or center driveshaft nager might be loose or worn.
God bless you
Jun 17, 2012 | 1994 Jeep Grand Cherokee
I recently purchased the pldnv78i. Where do I hook the key 1
I know that these wires are for "Steering control" finction.
Feb 27, 2012 | Pyle Car Audio & Video
My 1996 jetta horn does not work. Fuse / relay okay
hi did you also checked the horn itselfs. when you take out the horn and look at the back you will see a adjust srew with sealingmastic on it. you can remove the sealingstuff and try to adjust the horn. this only works if the coil is not broken. but first you have to check the connection inside the steeringwheel. make sure the switch in the steeringwheel is making contact to earth. if this all doesnt work you have to buy a new one goodluck.
Feb 16, 2010 | 1996 Volkswagen Jetta
Put ket in but i cant unlock steeringwheel
spray some WD40 in the ignition and move the steering wheel back and forth while pulling on the key or make sure your vehicle is in park all the way.
Feb 06, 2010 | 2001 Dodge Neon
Need to take the horn cover off steeringwheel
Disconnect the Battery before doing anything, then remove the screews.
Mar 20, 2009 | 2007 Hyundai Tiburon
Turn signal
It could be round or square (rectangular) depending on if it is an electronic (rectangular) or a regular (round) flasher... Both are available for your particular model.
Either way it should be located in the fuse compartment inside the vehicle. (The fuse panel is located in the left front kick panel (right by where your left foot sits).
Check fuse #17 (10 amps) in the panel before replacing the flasher, this is the flasher fuse...
Sep 16, 2008 | Hyundai Motor 1993 Excel
Pioneer AVIC-D3 Car DVD Player Logo
41 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
