Question about LG Televison & Video
How to connect lg tv antenna model AP-42SA10 - LG Televison & Video
2 Suggested Answers
  • 378 Answers
SOURCE: antenna required to connect ap 530in 802.11a mode
http://h17007.www1.hp.com/us/en/support/converter/index.aspx
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02566249/c02566249.pdf
according to the manual, the radio and antenna is built in, but you can opt for an external antenna.
Posted on Apr 25, 2011
Bought a tv that came out of a hotel model number32LC50C BRAND NAME LG SCREEN FLASHES NO SIGNAL WHAT DO I DO
Check that the antenna is connected and that a signal is being supplied to the tv.
Dec 31, 2017 | LG Televison & Video
I have a LG smart Tv the picture is very good but the picture is very blue ?
What is the model number of your TV?
What are the devices connected to every port of your TV?
Disk; Cable; Antenna; DVD; HDR; Ethernet; USB; Soundbar ?
is the picture better with other INPUT sources ?
Jun 10, 2016 | LG Televison & Video
I can't remember I only know the brand is LG and I really want to put antena but I'm not sure what noel number my tv I really need your help on how can I buy that so I will it in the philippines for...
You should not need a model number of your TV. Antennas usually work with any TV. You just have to know what kind of connection is on your TV. Is it a cable connection or is it just a wire connection? It will say "antenna out" on your TV. Then find the right kind of antenna to hook up to.
Nov 06, 2017 | LG Televison & Video
I have reprogramed a LG tv and it keeps says no signal after receiving 5 to 11 stations
Sounds like you need a better antenna or an amplifier for you antenna. But check first you antenna coax connection to make sure the electrical connections are tight. Also check your coax for breaks in continuity. You can do this with an Ohm meter. You should have near zero resistance center to center of the coax and same for the out shield. More likely the problem is not your coax but a weak signal from over the air. Also check to see that your antenna selector on your TV menu is not set to Cable but rather Air assuming your are wanting to pick up free over the air signals and not cable.
Feb 12, 2015 | LG 32LG30 32 in. LCD HDTV
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
I have an lg 3d tv model 50pz5507-za it has onlybeen used for gaming and watching dvds have tried to tune it in to watch freeview tv but picture keeps breaking up making it impossible to watch
Make sure you are connected to a good digital antenna, roof mounted and pointing to your local transmitter. If in doubt, have a qualified TV engineer come and check your antenna. It may be slightly out of alignment.
Jan 06, 2015 | LG Televison & Video
I have a 60LN5710 LG Smart TV. I want to connect to the internet. I plugged in an LG AN-WF100 dongle. At first I couldn't find my AP. A few days later I found it and connected to internet, however I...
Sometimes these types of issues are difficult to troubleshoot remotely (in this case, you've got 4 potential points to address: TV, dongle, router and ISP.)
If your TV and/or dongle utilize specific ports outside of the "norm," you may need to manually configure your router to allow for this.
Depending on the distance your AP/router is from the TV/dongle, the signal may not be strong enough. (Or, the signal coming from the AP may be present--you can confirm this with another wireless device--and maybe it's just the dongle itself has a poor range.)
Also, the dongle itself may be defective. Generally, there is some form of configuration that needs to be done, one way or the other, either on the computer, or on the TV itself (like a setup option).
Most likely, it's not an ISP-related issue.
Also, try to contact Sharp Technical support. They should be able to give you some recommendations that may prove helpful.
If all else fails, see if you can track down one of the dongles listed as being compatible in the TV manual, or find a dongle that's advertised as being compatible with your specific television, as that might be your best bet.
Good Luck!
Oct 12, 2013 | LG ANWF100 Wireless dongle
How can I extend the router's range?
Most routers have about 200m range. However, the actual range in real-time environment is much less. Generally the antenas are omni-directional, however, directional antenna can be used to improve range in one direction.There are two ways to increase the range/ coverage area (i) Adding external antenna of appropriate type (ii) Installing additional Access Point (AP) connecting it with the existing AP wirelessly in line-of-sight (creating WDS) OR connecting the two APs with wire, which is a better option as it provides robust and reliable connectivity between APs.
Based on my on-site experience, I suggest that you may relocate the AP to another location depending upon your network environment. It has always helped me a great deal. Placing the AP at the desk level, avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
HOPE IT HELPS...Let me know if you need any further clarification assistance specific to you AP make and model. Don't forget to rate the solution if I could have been of any help!
CreativeTECH
Dec 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Antenna required to connect ap 530in 802.11a mode
May 15, 2010 | HP ProCurve 530 (J8986A) 802.11a/b/g...
The manual for this AP states "If both Radio 1 and Radio 2 are set to the IEEE 802.11b/g mode, Radio 2 must be configured to an external antenna."
802.11a mode is only supported on Radio 2 per the documentation.
Mar 29, 2010 | HP ProCurve 530 (J8986A) 802.11a/b/g...
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
