Question about GE Dryers
Have a G E dryer and its getting warm but the clothes aren't dry
    Sergeant:
  • 435 Answers
Broken heating coils most likely , very common with age
usually one of the 2 breaks
Posted on Feb 09, 2015
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
SOURCE: Dryer takes too long to dry my clothes
The first thing to check is the temperature. start the dryer, and check it about 10-15 minutes in, is it very hot or kinda cool? IF its very hot, Look at the lint trap channel to see if there is a build up of lint, then remove the vent hose from the back of the dryer and make sure it has no lint in it and that it is clear all the way through the outside of your house. Make sure the flapper for the dryer on the outside is clear.
If it feels coolish, you will need to replace the heating elements, or a control circuit. Neither are expensive.
IF you do it yourself it could cost maybe $50-100. Since your asking for help here, I urge you to pay for a professional to repair the dryer which may run $150-200. You will have to decide if repairing the dryer is worth the investment.
Posted on May 10, 2009
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Whirlpool duet gas dryer
The question is are your clothes getting dry? The flame does not stay on constantly, but cycles on and off. Now if the clothes aren't drying properly, then the first thing to check is if you have good air flow coming out of the back of the machine and air flow completely outside where the vent exhaust to. If that is good then most likely your flame sensor has gone bad and needs to be replaced.
Aug 25, 2012 | Whirlpool GEW9250 Electric Dryer
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
I just got this HE dryer and the cloths aren't dry when the buzzer goes off. And the permanent press clothes are wrinkled... HELP! Plus it took almost 3 hours to dry sheets
It could have a faulty thermostat which shuts down to fast in drying mode, be sure and check that the vent is clear and not obstructed at all, thats the only way moisture has to leave the machine and dry the clothes
Jun 17, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer heats up but clothes won't dry
Check that the lint filter is not blocked or that the oulet hose is not kinked
Feb 04, 2010 | Dryers
Dryer is not drying clothes very well
check your wall vent,if it is clogged it will not dry right-mike
Jan 24, 2010 | General Electric DHDSR46EGWW Dryer
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer will not get warm will still run, product only 4 years old. clothes will not dry
dryer will not get warm will still run, product only 4 years old. clothes will not dry
Oct 16, 2009 | Whirlpool Dryers
Dryers Logo
52 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
