Question about Miele T9800 Electric Dryer
Roper dryer wont heat - Miele T9800 Electric Dryer
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Hi i have a roper electric dryer and it will go threw all the cycles but wont dry clothes like wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Roper REX3614KW Electric Dryer
Roper dryer timer will not advance and there is no
It wont advance because the heater isnt functioning.
Check to see element reading then temp. thermoststs normally found on heater body.
Jun 06, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Jul 25, 2009 | Roper RES7646KQ Electric Dryer
Dryer wont heat up to dry. need to change fuse possibly, alrweady checked lint trap/hose/exhaust
these few things that you may want to do.
Roper Kenmore Dryers are almost the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
If this wont solve the problem let me know.
It was helpful?
May 15, 2009 | Roper REX3614KW Electric Dryer
Roper dryer
what do you mean wont cut off ?? the heat?? the drum? was this on the top part of the heationg element?
Jun 09, 2008 | Roper RES7646KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Miele T9800 Electric Dryer Logo
43 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
