Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer not working
The top drawer has power going through but it continually beeps and the display flashes. No fault code appears. It appears to have stopped half way through a washing cycle. I cannot turn it off via the power button, it continues to beep and flash. The bottom drawer works perfectly. Please help.
  • Anonymous Jan 09, 2008
    My top drawer has water remaining in it, the panel is flashing random numbers and pictures non stop and can't shut it off. Can't drain, etc. Repairman says diagnostic burnt out and can't run until parts are put in.
    Sergeant:
  • 351 Answers
Sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Posted on Mar 03, 2008
Fisher & Paykel dishdrawers - no power at all to the top drawer
Try and do a power reset to the dishwasher. This means turn the mains power off to the dishwasher and back on again. If there is no mains socket under the kitchen bench then maybe do this from the mains contactor switch in the meter box. If there is no difference to the behaviour of the top drawer then the controller has most likely packed up. You can test things out by taking controller from bottom drawer and putting in top drawer. But this requires some experience with taking out the front covers of the drawers, taking out the connectors and putting back. If you mix the connector connections etc you can cause more damage. Take photos as you go along. Make sure the dishwasher is disconnected from mains power when you are working on it.
Feb 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
No power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Sep 09, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher bottom part works top part all lights are on and wont work
I'm assuming its a fisher and paykel, you will certainly need more info. Do you have an led display or 3 buttons and lights. Any fault codes, flashing beeping when buttons are pressed etc. If everything is normal no unusual beeps lights etc but nothing AT ALL happens when you press start it is the door 'switch' which is actually a light that is reflected through a plastic prism and back to itself ( originates from the board) check the prism top right drawer frame. Just compare to working drawer. If not more info required.
Jul 07, 2013 | KitchenAid Dishwashers
Dishdrawer cannot open
the power board at the base of the dishwasher under bottom drawer appears to have blown up. Take the bottom drawer out carefully to access the power board. Make sure the mains power is turned off.
The reason the bottom drawer is not getting back in is that lid seal actuators are stuck as the motors are in close position. Will reset to normal position once the power is restored. So don't try to push the drawer in as the lid seal will be damaged.
Feb 15, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
470 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
