Question about Krups KM7000
Grinds but won't brew
Unit grinds, then "clicks" but nothing else happens.
    Scholar:
  • 22 Answers
If your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Posted on Jan 31, 2010
  • marsaudio Apr 27, 2011
    Mine is now grinding with the lid closed and when the hotplate comes on after grinding it shuts the hot plate off!!!What do I do?
    Problem Solver:
  • 17 Answers
Check to see if warming plate heats up, if it doesn't the heating plate/water heater is bad.
Posted on Dec 22, 2009
Gaggia accademia grinds too much
Make sure that your brew unit is clean and lubricated. The CPU on the machine uses the brew unit to calculate the amount of coffee it grinds. If the brew unit is dirty and hard to turn strange things will happen.
Service Center information.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Apr 27, 2014 | Coffee Makers & Espresso Machines
Coffee grinds but nothing comes out of dispensing head. Brew group wont come out.
I have the exact same problem and haven't found any replies to your request. Did you finally find a solution to the problem? Thanks
Dec 11, 2011 | Saeco Odea Giro Plus Coffee Maker
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Is there a way to increase/decrease the pressure of the brew unit tamper?
Hi
Yes in a way. There is a lever on the right side above the center of the door. It has a + and -, on it and the + will increase how much coffee is put into the brew unit and - will decrease the amount. + is for stronger coffee and - is for weaker coffee. The grind will also affect the compactness of the brew unit but you can get too much pressure if you get it too fine and this can also clog the passages of the grinder if made too fine. If you ever get the machine to say that "you are out of beans" and there are beans in the bean hopper, your grind is too fine. If the flow from the brew unit slows down your grind is too fine. If it dumps the grinds or makes a clicking noise you have too much coffee going into the brew unit. Pull the lever back 1 click from the +.
Oct 23, 2010 | Saeco Magic Comfort 103467 Espresso...
Cusinart 12 cup grind and brew overflows with grinds and water
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Hot steam dampens coffee grinds in grinder unit
These grinds are what is left after the grind process is finished. Everyones unit does this.
Mar 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Krups KM7000 Logo
445 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
