Question about Easy Kaiboer K610i 3D & Android High-quality IPDVD Player
How to master reset on kaiboer k610i - Easy Kaiboer K610i 3D & Android High-quality IPDVD Player
How to format mmory of sony ericsson k610i mobile phone
to format sony ericson mobiles follow the step
step1. go in menu and enter in the setting option
step2. in setting menu search for master reset or factory setting option.
step 3. enter in master reset option it will ask you for code.
step4 enter code 0000
now you are done.
0000 is default code it will work unless you have changed it.
Feb 10, 2011 | Sony Ericsson K610i Cellular Phone
How to reprogram k610i
How do I reset my phone back to its original settings? Press Menu
Scroll to "Settings", press Select
Scroll to "Master Reset", press Select
Scroll to "Reset Settings" or "Reset all", press Select
Press Continue, press Continue.
Note: This will reset the phone to its factory settings - all personal settings may be lost
Only do this if you are certain you want to revert to the factory settings.
Jan 20, 2011 | Sony Ericsson K610i Cellular Phone
I forgot the lock code of sony ericsson k610i plz help me
by the use of master reset code you able to unlock your cell phone from the following link u can get your master reset code
http://www.unlockcellphonecode.com/index.php?osCsid=0a903925bfd2886063779d5965aaf5cf
Jan 06, 2011 | Sony Ericsson K610i Cellular Phone
I want to how to give hard reset in k610i but how can i give it can you please tell me step by step
hi
if u want to reset your phone .. then take your phone data reset . process is setting >>>>> master reset >>> reset >>>>
...then your phone will be reset ted
thank you
Dec 22, 2010 | Sony Ericsson K610i Cellular Phone
Code unlock for sony ericsson k610i pls help
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope its ok!
Nov 14, 2009 | Sony Ericsson K610i Cellular Phone
K610i master reset now my phone just has a white screen
hi you will need to flash over your phone using xs++
if you need any more help let me know
Aug 10, 2009 | Sony Ericsson K610i Cellular Phone
Phone works but camera blocks the whole machine
check for the memory on the handset also try performing a reset settings on your handset.
steps for reset settings :Menu--Settings--Master Reset--Reset settings..
Please remember this would not delete any of your data but the phone will go back to the original settings
Jul 26, 2008 | Sony Ericsson K610i Cellular Phone
K610i PROBLEM
You should be able to down load the latest softwear off the Sony Ericsson website. Otherwise the phone should have a 12 month manufactues warranty and can have it done for free at an authorised Sony Ericsson repair centre.
Apr 11, 2008 | Sony Ericsson K610i Cellular Phone
Sony Ericsson K610i
master reset once keeping the backup of ur phone ... and also format the memory card also once ...
Dec 18, 2007 | Sony Ericsson K610i Cellular Phone
K610i
no it is not.....try a master reset if that does not work then try a reflash of the firmware on teh phone take it to a mobile store to have that done.
Dec 03, 2007 | Sony Ericsson K610i Cellular Phone
Easy Kaiboer K610i 3D & Android High-quality IPDVD Player Logo
118 people viewed this question
Top Easy Audio Players & Recorders Experts
Tom Chichester
Terry
Terry
Badre Errguibi
Badre Errguibi
Level 1 Expert
Are you an Easy Audio Player and Recorder Expert? Answer questions, earn points and help others
